SOURCE: Clicking noise from under the dishwasher & Its a new dishwasher
Maggie, what you are hearing is probably the drain pump solenoid. At start the drain pump will get in to get rid of any water and purge the system. It's hard to tell without being there. I would call for service, it won't cost anything. Have the tech check the wash and drain pump assy. Catriver..post back.
SOURCE: 665.17019401 - Kenmore diswasher
It indicates a water temp problem. If water temp doesn't rise at a certain rate, by the heater, it goes into this error. Probably a problem with heater or wires to it.
SOURCE: problems with Whirlpool dishwasher model GU1500XTKB0
will these units (silo and jtrip) start back on their own? if so, it is likely they are heating the water.
otherwise it sounds like a logic board, unless there is a defective door switch or sensor issue.
electronics seem to be a recurring problem with whirlpool.
i would ask whirlpool (electorlux) to either buy it back or fix it.
good luck
mark
SOURCE: Machine won't start and clicks if turned on with door open
Ok,
this is the fix:
No
payload. Close the door. Press off, then press on. Then enter a program
starting by selecting the fabric and the others as usual. Do not press start,
instead press the slip button to advance the programme to the very last phase,
ie drain and empty. Then press start. It will perform this operation with no
load and pump out the “no water”. This part takes 5 minutes. After the 5 mins
the programme will end and the machine will beep annoyingly, but the computer
will be reset and you can clear the program and use the machine as normal.
Why?
I had
the same problem. The stupid computer inside remembers the program whilst it’s
off and unplugged. What has happened is you accidently pressed start and start
again to pause it in very quick succession. This confuses the computer and it
thinks that a program is in progress. This is why it wants to close the door. There
is no problem with the latch (unless it is a separate problem). You have to let
it play out a program to reset it, which is why you can play the very last “drain”
segment.
Question.
Presumably
there’s a way to reset the computer either by a secret button combo or shorting
out two pins from the computer box. I don’t know. If someone knows this please
tell me.
Good Luck!
SOURCE: Vinotemp LG 16TEDSW
It sounds like you're having a control board PCB issue. You can often get replacement parts directly from Vinotemp. Of course, I'm sure the issue will be easier to resolve if your unit is still under warranty. If not, they should still be able to sell you the parts you need and then you or a qualified repair person can replace whatevers needed. Instructions for some service issues can be found on the Vinotemp website in the Customer Service section. You can also request service for your unit there. Hope you get it fixed!
Hello - Try resetting the dishwasher by disconnecting the power to the unit. This will clear most flashing lights. You can disconnect power by flipping the circuit house breaker off and back on for approximately two minutes. If this does not prove to be successful, contact a professional to move forward accurately. Dishwasher could possibly have a faulty control board or wiring failure.
