Small
Good Afternoon friend, thank you for your post!
I understand that you have some standing water inside of your Frigidaire dishwasher. It is a normal operation to have anywhere from 2 to 3 inches of water inside of the tub of your dishwasher. If it is anything more than that you could have an issue with the drain pump or drain line.
You may want to check the drain line for any restrictions or clogs that could cause improper siphoning from your dishwasher. You should also make sure that the filter located in the bottom of your tub is clean, that could cause water to stand within your dishwasher. I hope this information is helpful. -Matt
SOURCE: Our GE Dishwasher model GLD4500N00BB will only
Look for restricted drain system. Screens and ports get plugged, also verify the drain hose is NOT kinked at all. Hot water draining relaxes hose and can cause restriction.
SOURCE: I noticed water leaking underneath
Sorry to read about your problem, I hope this helps you out.
since you turned off the water, and the leaks stop, it is in the water line feed, up and to the machines water inlet valve. you might have a chance of a defective water valve, also leaking a little...
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
