20 Most Recent Zanussi 24 in. DE6744S Free-standing Dishwasher Questions & Answers
On the side of the units there is a matrix (up and down tubes ) they need cleaning but I will warn you the pipes from the drain and through the matrix are gummed up with a disgusting sludge. There are some push on fittings and some held with spring clips take some photos when disassembling but it is easy just time consuming trying to flush the gunk
Zanussi 24 in.... • Answered on Sep 19, 2014
The Drain pump can be got to by removing the circular filter at the bottom of your machine and all the screws that hold the plastics in including the round retaining plastic clip, only then will you see your drain pump prepellors, but if you want to remove the Drain Pump then this can be done from the rear of the machine you might have to remove the macine outside for this as you need to turn it on its side, from the back of the machine remove the two screws holding the big electronic motor this is plugged into electric sockets remove them also there is a rubber bung that holds this in place once unscrewed the motor needs a bit of a jig and it should slot out through the back of the machine. If you are thing of changing this it costs about £120 I got rid of the machine myself.
Zanussi 24 in.... • Answered on Aug 04, 2010
Zanussi all recommend Finish
Zanussi 24 in.... • Answered on Aug 03, 2010
There is a small round solinoid that might have blown its just under the element, you could try this, it cheaper option.
Hi, the first thing the dishwasher does is fill with water, so this sounds like a Anti Flood water pump problem this is just behind the water pipe that feeds the clean water into your machine, one thing to check is if the machine is empty of water at the moment, if the machine has water in the bottom then it could be the Drain Pump.
I have this problem at the moment and I have just purchased a new Drain Pump, I will let you know how I get on.
The problem is with the PCB, this is the board behind the buttons, you can buy this for £120 or you can get it fixed by QEA for about £45 link below. I am not an engineer but I replaced mine in 10 minutes.
http://www.qualityelectronicrepairs.co.uk/lists/laundrymodels-zanussi_1.html
Look at 110v feed...from timer......
Zanussi 24 in.... • Answered on Aug 18, 2009
You need to refill the rinse aid dispenser
Zanussi 24 in.... • Answered on Apr 08, 2009
ANTI-FLOODING CONTROL SYSTEM ALARM [A L 4] Leds [LD9] + [LD10] This control system is operative during the washing phases only, and not in the water fill phases, in which case is it connected to the safety device (see paragraph 7.4.1 ?Water Fill Time-out?).  A float-actioned mechanical sensor positioned on the bottom of the appliance trips a microswitch which is connected in series to the fill solenoid, thus disconnecting the solenoid.  Intervention of the sensor is detected by the electronic control board, which actions the drain pump for 1 minute, after which an alarm condition is generated. Possible causes: a. Water leakage from the tub/sump seal b. Water leakage from the various couplings (motor, OR on the duct to the upper spray arm, etc.) c. Floating sensor jammed mechanically/microswitch faulty
Zanussi 24 in.... • Answered on Feb 26, 2009
don't replace heater till you have tested continuity across it other items which can cause no heat are module temp sensor
Zanussi 24 in.... • Answered on Jan 20, 2009
Try to unplug the power cable for few houres and then plug it again. It mighet reset the control unit. Good luck !
Zanussi 24 in.... • Answered on Jul 24, 2007
it sounds like the recirculation pump bearings are going and it needs to be replaced or yo may have an obstruction in it.
Zanussi 24 in.... • Answered on Jul 10, 2007
There are a lot of reasons could cause this issue. Could you provide us more details (if you have) which cycle's stage "takes" this time (filling water, washing process,draining etc... ) You answer will allow us to direct you the solution. Good luck !
Zanussi 24 in.... • Answered on Jul 05, 2006
exercise to lose belly fat; fat loss extreme; workouts to lose belly fat; best foods to eat to lose weight; diet for weight loss for female; dr now diet plan; simple 1200 calorie meal plan; meal plan for weight loss and muscle gain female; 1200 calorie a day meal plan; lifting weights to lose weight; foods to eat to lose weight; lunch for weight loss; healthy lunch for weight loss; healthy foods high in fat; https://behealthyideas.com/ <ahref="https://behealthyideas.com/">https://behealthyideas.com/</a>
Zanussi... • Answered on Apr 09, 2021
Zanussi 24 in. DE6744S Free-standing Dishwasher Logo
31 questions posted
Top Zanussi Dishwashers Experts
Paul Carew
Renee Knafel-Bullock
ray gallant
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Zanussi Dishwashers
  • Zanussi Dishwashers
Most Popular Question
drain pump located zanussi
  • Dishwashers
