Kodak Easyshare Max Camera Z990 Digital 12.0MP - Kodak Logo
A
Anonymous Posted on Mar 06, 2015
How do I get images that are visible on camera (sd card) but aren't visible when trying get prints from kodak or fugi machines at Sam's or Walmart?
Montani
Level 2:
Novelist:
  • Expert 235 Answers
  • Posted on Mar 10, 2015
 Montani
Expert
Level 2:
Novelist:
Answers
235
Questions
5
Helped
67377
Points
450
It could be the format of the pictures. Most machines will only see jpg or bmp files.
I have akodak easyshare c633 camera have had it for bout 3 years with no problems.Ive decided to purchase a new memory card for it instead of just putting prints on a cd at walmart.The full card is a...
Your camera cannot use SDHC cards....only SD. If you copy and paste this address into your browser, you can download a copy of the owner's manual. http://www.kodak.com/global/plugins/acrobat/en/service/manuals/urg00634/C633_GLB_en.pdf
Can i get 4gb sd memory card for kodak dx4590 camera
You can easily get the 4GB SD Card from any local stores like Staplse, walmart, Bestbuy or any Computer Sales and Service Shop/Center.
Regards,
FixYa Team
We took our 512 mb SD Card out of our camera to download some of the pictures to a digital picture frame. When we return the SD Card to the camera amessage appears "memory card requires formatting. I know...
You can either use a separate card reader to download to your computer, or , take the card to a Walmart store and insert the card into a Kodak Picture Kiosk machine and print the pics or make a cd of them. Then, format the card in the camera.
1helpful
Kodak easyshare m360 says memory full after 3 photos i just bought the camera, what i shell do < shell i buy memory card or usb for it ?
You need to switch the camera over to saving pictures directly onto the SD card.
  • Menu
  • Cam settings
  • Chose AUTO or SD card option
  • Press OK to SD card
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
If you experience problems:
The lever on your SD card might be turned the wrong way so the SD card is reading protective.
Please turn the lever and try again.
The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 2 Gigabyte and SDHC up to 8 Gigabyte
The SD card might not be faulty, try another card, since the camera could give you a message like the one you're experiencing.
Try with a different SD card that is supported by the camera.
Once you have set the settings to save onto the SD card directly you might like to transferre your existing pictures from the internal memory onto the SD card:
Question :
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card? Answer :
Follow these steps:
  • On the camera, press Review and then Menu.
  • Select Image Storage.
  • Change to Internal Memory.
  • In the menu listing, scroll down to Copy, and select OK.
  • Select a single picture, or select All.
  • When you have finished copying pictures, reset the Image Storage location to your original setting.
  • 1helpful
    Having problems with memory card/camera. it says no image when i want to look at the photos i took, but i no i didnt delete them, does this mean i've lost the pics i took last night
    Did you remember to format the card in the camera before trying to use it with this camera? Anyway, if indeed pictures exist on the card, take it to a store like Walmart that has a Kodak picture maker machine and it will be able to retrieve your pics. You can print them or even make a cd of them.
    5helpful
    2answers
    Internal memory is full
    If you have SD card already but same message. Make sure that the Image storage is set to AUTO not Internal Memory. You may try steps below.
    1. Press the Menu button
    2. Select the Settings Tab (it has camera icon w/ tool or wrench icon)
    3. Scroll down until you select IMage storage then press OK
    4. select Auto for SD card and OK.
    Thanks.
    Neerak21
    2answers
    I took picture w/o SD card. Don't know how to transfer to SD
    Search the menus for an entry for "copy". It should give you the option to copy the internal memory to a memory card. You could also take the camera and a usb connecting cord to a store like Walmart that has a Kodak picture maker machine. You can plug the camera into the usb slot and print the picture.
    Memory Card Error
    You could take the card to a store that has a Kodak picture maker machine (Walmart, etc.). From there, you can print your pics or even make a cd of them. The card may be faulty or just may not work in Canon cameras.
    Printer will not read SD card from Panasonic Lumix DMC TZ3
    Put the card in an adapter or in your computer. Make sure the pictures are not in folders. The printer is unable to read them if they are.
    Also, the file size of the picture cannot be over 8 MB and the image size has to be below 12 megapixels.
    1helpful
    SD CARD
    If I remember correctly, when you insert an SD card, it "hides" the camera's internal memory. There should be an camera option for copying the files from the internal memory onto the inserted SD card. If not, you could try connecting the camera to your computer with the SD card removed, in order to access the files in the internal memory.
    Top Kodak Cameras Experts
    ZJ Limited
    ZJ Limited
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a Kodak Camera Expert? Answer questions, earn points and help others
