Hello Tom, Sounds like all you need to do is a fresh reinstall of the software and everything should be fine. This is a normal problem with Microsoft Windows.
SD/SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Many cameras will not display pictures that were taken with a different type of camera. You should still be able to view those pictures on the original camera, a computer, or a digital photo frame.If I may make a gentle suggestion, use your camera to take pictures. To display them, use something better suited for the task.
JustAnswerhttps://www.justanswer.com > Electronics Question
Mar 5, 2020 - Your old camera model DX7630 only supports SD memory card type, which has size of 2GB or less. Your camera does not support SDHC card type ( ...
1 answer ยท Top answer: Hi, I'm sorry about your camera issue. I'm glad to assist you today. Did you purchase new ...
ZDNethttps://www.zdnet.com > product > kodak-easyshare-d...
The camera includes an SD memory card slot located next to the battery compartment. The purchase of a 128MB or greater SD memory card when you buy the camera is ...
Pros and cons: Picture quality is excellent ? Battery life is excellent ? Easy to use menus ? View full list
