I have restarted my wi-fi and kindle this has happened out of the blue I finished a book and went to read new one and kindle is not connected for some reason
My monther's issue was because her ISP's (Bell) router, home hub 3000, comes default with the 2.4G and 5G SSID named the same with the same password. So her 2.4G was on a Band that was super weak, like 30%, but her 5G was at 90%. This was causing her wifi connections to use 5G as it was more available. Problem with the kindle is that it is limited to use the 1 - 11 channels / 2.4G only. I resolved this by going to the routers config (192.168.2.1) and changing the SSID from Bell553 to Foxtrot. Then i changed the 5G SSID to Foxtrox-5G and made different passwords for both. Rebooted the router and the kindle was able to connect to the 2.4G network.
Can you connect other devices to your wifi using the same password?
If so, it is the Kindle at fault.
Go to your wifi connections in Settings and remove your connection (I think it may say "forget").
Turn off your Kindle by holding down the power button for a full 30 seconds.
Restart your Kindle and connect to wifi, re-entering the password on the back of your router.
