20 Most Recent Amazon Kindle Model D00901 Tablet Reader Buy It Now Questions & Answers
Your kindle has a sim card installed for 3G (lifetime licence paid by amazon and paid for on purchase price on the unit) but that is not related to the wi-fi function on your kindle. Your wi-fi service needs to be logged in to with the same password as you use to log any computer on to your router when at home or whatever wi-fi password is required when elsewhere (e.g a bus, train or restaurant).
Amazon Kindle... | Answered on Jul 03, 2020
Here are three links to pages with info on the Kindle D00901.
1. http://www.kindlewirelessreading-device.com/Model-Number-D00901.html
2. http://kindle.s3.amazonaws.com/Kindle_6inch_Quick_Start_Guide.PDF
3. http://kindle.s3.amazonaws.com/Kindle_User's_Guide_English.pdf
To contact Amazon, go to www.amazon.com, scroll to the bottom of the screen, click Help (under Let Us Help You), click Device Support and then scroll down to find your device. Once you've found your device, click on the link and you can continue looking for information there or you can click on Contact Us on the left hand side. If you click Contact Us, you'll be asked to log in to your Amazon account.
Amazon Kindle... | Answered on Feb 29, 2016
look along either side for a small hole . that might reset the device by pushing a paper clip end in gently
Amazon Kindle... | Answered on Feb 09, 2015
If this is a first generation Kindle Fire, then you are in good company, and the problem may not be the battery itself (which is good, b/c the battery is not user replaceable, at least for non-techies). Refusal to charge is apparently a very common problem, which seems to have multiple contributing factors. The charging port sometimes gets 'loose' or dirty, so I would suggest trying that first. Vacuum or blow out any dust/dirt, then look at it under a bright light and perhaps with a magnifying glass to see whether any portion is bent or twisted. If all looks OK, then I would try plugging it in and gently moving the cable around a bit to see whether the charge light goes on and off. If so, you might be able to still charge it by 'propping' the cable to gently nudge it in the direction that causes it to connect. This is a relatively short-term solution, as it will eventually stop working. Another problem seems to be in the 'programming' inside the Kindle, such that, under certain conditions, even with a good charger and cable, it will not take a charge. A common trick, when this seems to be the case, is to ensure that it has fully shut down before trying to charge. For some reason, if it is fully shut down, it is more likely to 'accept' a charge. Push the power button (with the charge cable unplugged) and hold it for at least 20 seconds. After that, it should be fully shut down. Then connect the cable and look for the orange light. If you get it, then leave it alone (verify it stays on when you lay it down, and 'prop' as needed) and preferably leave it to charge all day or all night, or until you see the charge light has turned green. If none of that is successful, and especially if you cannot get the charging light to come on no matter what you do, then try a new cable (cheap ones won't do) and/or a new charger. Borrow from a good friend for a cheap test. We just gave up on ours, after several months of nursing it along using various methods. It is a shame, because the device (except for weight and thickness) has been fantastic for my wife and then my daughter. I hope you manage to get a lot more time from yours!
Amazon Kindle... | Answered on Jul 18, 2014
model number please
Amazon Kindle... | Answered on Aug 27, 2012
here you go
http://www.amazon.com/gp/help/customer/display.html?nodeId=200212360
You may have to reset it to factory settings. Never break optimization process. It may take a while if there is many apps installed
Amazon Tablets &... | Answered 2 days ago
You would either have to do it yourself, which is cheaper but you need experience, or you would have to bring it in to a repair shop and they can do it for you.
Amazon Tablets &... | Answered on Sep 18, 2020
Time to buy an iPad Mini. Even the maker doesn't know how to fix it and shortened the warranty on purpose to cover up the issue of replacing them.
Has Your Kindle Fire Tablet Flipped/Reversed Its Screen ...
the-digital-reader.com > 2016/05/31 > has-your-kindle-fire-tablet-flip...
May 31, 2016 - Text and layout backwards and upside down. straight out of the box. The screen flickers as well, so the underlying problem might be more than ...
https://www.google.com/search?q=Amazon+Fire+display+is+upside+down+and+backwards
Amazon Tablets &... | Answered on Aug 08, 2020
To buy content and deliver it to your device, you will need to connect to a wireless network and register your Fire tablet to an Amazon account.
If you are setting up a new Fire tablet for the first time, you'll be taken through setup instructions and will have the chance to register your device. Follow the instructions on your screen.
To register your Fire tablet outside of the initial setup screens:
  1. From Home, swipe down from the top of the screen and then tap Settings.
  2. Tap My Account.
  3. Tap Register.
    • If you already have an Amazon account: Enter your Amazon account information, and then tap Continue.
    • If you do not have an Amazon account: Tap Start Here, and then follow the instructions to set up a new account.
Note: If you've forgotten your Amazon account password, you can reset it by requesting that a personalized "password reset" link be sent to your e-mail address. To learn more, go to Reset Your Account Password .
If you need to deregister your device from an Amazon account, follow the steps above, and then tap Deregister. After you deregister your device from an Amazon account, you won't be able to access items stored in the Cloud for that account.
After deregistering, you can register your Fire tablet to another Amazon account. Related Help Topics
Amazon Tablets &... | Answered on Jun 22, 2020
Hello Peggy Wilson, If you are having any kindle of issue with your Amazon kindle like Download Kindle App, Amazon Kindle Update etc then you can take kindle support from the experts by calling their toll-free number.
Here is the link and toll-free number try it once you will defenitely get your solution.
Amazon Kindle Help Support Toll Free Call 1844 305 0086
Amazon Tablets &... | Answered on Mar 12, 2020
How would we know that?
You should really contact Amazon customer service and check that issue with them.
Amazon Tablets &... | Answered on Feb 04, 2020
Amazon help desk might be able to find if if you have an old routing number for a product you ordered. The help desk will want you to supply the email address by which you set up the account, at minimum. You can try logging in and going through the security questions for a password. If you can't supply the help desk with any of this information, you likely will have to set up a new account.
Amazon Tablets &... | Answered on Dec 21, 2019
account number with amazon - Amazon.com
https://www.amazon.com > account-number-amazon > k=account+number...
How To Update Amazon Account Profile And Credit Card Information In 1 Minute: Guide With Screenshots On How To Update Your Amazon Account Profile ... Missing: require ‎' ‎Must include: ‎require
Registration requirements by marketplace - Amazon Seller ...
https://sellercentral.amazon.com > help > external
You will need to provide a valid credit card, bank account, phone number, and tax information. You will also need to go through an online step-by-step interview ...
Amazon.com Help: Account Settings
https://www.amazon.com > help > customer > display
Managing Your Account>. Account Settings. Change Your Account Information. Add & Manage Payment ... Change Your Recommendations ... Account Details.
Amazon Tablets &... | Answered on Nov 24, 2019
Connect Amazon Tap to a Wi-Fi network. Follow the instructions in the app to connect Amazon Tap to a Wi-Fi network. If the setup process does not automatically start, press and hold the Wi-Fi / Bluetooth button on Amazon Tap for five seconds. Then, open the Alexa app, and go to Settings > Set up a new device.
Amazon.com Help: Set Up Your Amazon Tap
https://www.amazon.com/gp/help/customer/display.html?nodeId=202014730 set up alexa amazon tap Bluetooth Google Search
Amazon Tablets &... | Answered on Nov 21, 2019
contact amazon then.
Amazon Tablets &... | Answered on Nov 19, 2019
You can get best amazon fire support phone number at Toll Free Number ( 1-877-769-0969 ). Amazon fire Tech Support number ( 1-877-769-0969 )
Amazon Tablets &... | Answered on Nov 12, 2019
Register Your Fire TV Edition TV to Your Amazon Account. Select Settings > My Account. Select Register and enter your Amazon account information when prompted. If your device is already registered, the associated name appears on this screen.
Amazon Tablets &... | Answered on Nov 08, 2019
Amazon Kindle Model D00901 Tablet Reader Buy It Now Logo
6 questions posted
Popular Products
Top Amazon Tablets & eReaders Experts
Sheldon Dedek
William Alequin
Andrew Taylor
Andrew Taylor
Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • Amazon Tablets & eReaders
Most Popular Question
need free manuel phone number call
  • Tablets & eReaders
