Question about Amazon Kindle 3G
Kindle fire wont connect to open wifi
My first gen kindle fire will not connect to certain open access wifi hot spots, like at the gym (free wifi to guests) or in certain times around my college campus. it says it is connected on the wifi page, but the wifi symbol shows an x at the bottom of it and won't connect to anything. HELP
jackson Cooper
  • 3 Answers
Here are few steps to resolve kindle won't connect to wifi issue:
  1. Re-connect The Network: Try to solve your problem by reconnecting the network. There would be some common issues that interrupt your network connectivity but easily get sorted out by just reconnecting. First, press the wifi icon and then you look for your network, have you found it? Great, now disconnect and reconnect it.
  2. Remove The Barriers: If there are any barriers like- almirah, wall, curtains or even a person, then either remove them or replace your device, as you like and comfort you. Barriers do not allow the network to pass properly, it unstable the network. So, just consider this point and take action.
  3. Check The Airplane Mode: If you do not know then let us clarify to you that when the Airplane mode is turned on then your network automatically gets turned off. So, check the Airplane mode, make sure it would be off.
  4. Check The Battery Status: Do you know the low battery also leads to network issues? To run the network smoothly and properly without any hurdles, charge your Kindle properly.
  5. Restart The Kindle: If you followed all the above steps properly and are still facing the Kindle fire not connected to the wifi issue then just restart your device once. There are some internal issues that may get solved instinctively on their own. So, just turn off your Kindle, wait for 1 or 2 minutes, and then again turn the Kindle on.
I hope these steps will give you relief from this issue quickly. If still you are facing this issue then check out this article https://ebookhelpline.com/kindle-wont-connect-to-wi-fi-issue/
This will help you.
Posted on Nov 16, 2020
Robert Hogan
    Problem Solver:
  • 28 Answers
Kindle won't connect to wi-fi don't worry. Check out the instructions to fix the issue.
read here: https://www.ireadebooks.com/kindle-problems.html
Posted on Jun 13, 2020
Camila Hill
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 11 Answers
Kindle wifi solution
  • Restart your Wi-Fi connection on your device. Swipe down from the top of the screen and tap Wireless, and then tap Wi-Fi.
  • Restart your device. ...
  • Move closer to your router. ...
  • Use Channel 1-11. ...
  • Restart your router and modem.
Read More: https://www.digitalbulls.com/ereader-24-7-support-at-an-affordable-price/
Posted on Apr 29, 2020
Eric Sutherland
    Master:
  • 665 Answers
4 Related Answers
Anonymous
SOURCE: Kindle stopped working. When I
Apologies, this is not a solution, but just to say that I currently have exactly the same problem. Have you managed to fix yours?
Posted on Jan 04, 2011
White Zombie
  • 4961 Answers
SOURCE: `kindle fire
Sounds like your power cord is dead and that it's not charging. If it's new bring it back to the store you bought it from and get a new one.
Posted on May 15, 2012
liam kirk
  • 15 Answers
SOURCE: My kindle Fire doesn't recognize my WiFi selection
what message do you get when you try to connect to the wi-fi?
Posted on Sep 29, 2012
TechyDrood
Justin
  • 2072 Answers
SOURCE: trying to connect kindle fire to wifi TheGriswalds has come up but do not have password help
Ask someone for the password, or if this is your router then you may need to factory reset the router and setup a new password
Posted on Dec 08, 2013
My new amazon fire wont regester my pasword
To enlist your Kindle Fire tablet
Access the fast settings menu by swiping down from the highest point of the screen
Tap Settings symbol
Tap My Account
Tap Register
Tip: Tap the Fire Generation 8, Fire OS 5, Fire Gen 8, Register Fire Gen 8 key to enter numbers or images. Tap the ABC key to come back to the consistent console. Tap the Shift key (up bolt) for capitalized letters. Tap the crate beside Hide secret word to show your watchword as you write.
Whenever completed, tap Register once more. Your name will show up as the enrolled client.
Click here for more information
Kindle Fire Troubleshooting
Jan 21, 2017 | Amazon Kindle
My kindle won't access the WI-Fi
John,
Is it on a particular Wifi Connection?
Are you able to connect to other Wifi? Or other devices works fine on this particular Wifi Connection?
Go to Settings < Wi-Fi < Click/Tap on the Wi-Fi Network and Choose Forget
Enter the Password again and make new Connections.
It May help.
Oct 08, 2016 | Amazon Kindle Fire HD
No longer will connect with WIFI although all other electronics are on the WIFI
Amazon.com: Customer Discussions: kindle won't connect with wi-fi
www.amazon.com/forum/kindle?_encoding...
Amazon.com, Inc.May 7, 2012 - If it will connect there, then the issue is not your Kindle but the network..... I just received a Kindle Fire HD as a gift and was able to connect to the ... It used to say "obtaining IP address" but it no longer says that, so I know there ... My Kindle will not stay ...
Oct 24, 2013
Kindle Fire HD 7" WiFi Not working
May 28, 2013
kindle fire hd connects to wifi ...
Jan 5, 2013
New Fire HD drops wifi!
Sep 19, 2012
More results from www.amazon.com
Amazon.com Help: Can't Connect to Wi-Fi
Dec 20, 2015 | Amazon Kindle Fire HD
I cant get wifi on my kindle fire
Yes, but you first need to be in range of a wifi access point. If it is not a free/open access point you will need a password.
Oct 07, 2015 | Amazon Kindle Fire HD
I have had Wi Fi on my Kindle Fire and now it will not connect and keeps asking for an IP address
When you connect to Wifi and if it shows "obtaining IP address" means it is searching for the IP address of the wifi sender...
when you connect to internet it is done through IP address so your phone is tying to locate an IP address with which it can connect
to the internet. Below are the steps to connect your device to Wifi:
Applications-->settings-->turn Wifi ON-->select the wifi that you want to connect from the list displayed-->enter the network password(if it asks for) -->connected Another easy way...just open the chrome app in your phone and try typing in some website like google.com when it tries to connect a pop up will appear "try connecting to WiFi ..mobile data will incur charges.." something of that sort...and you can click connect to wifi...and automatically it will detect the wifi that is around your location. You can check for your IP address through Ip-details.com
Jul 12, 2015 | Amazon Kindle Fire HDX 7
Iconnected to another wifi and now it wont connect to my home wifi help
First, make sure you are not in airplane mode (this shuts down the wifi).
Then ensure you are not connected to any wifi routers - if yes, then disconnect.
Finally, let the Kindle search for your wifi.
http://www.amazon.com/gp/help/customer/display.html?nodeId=201175730
Apr 29, 2015 | Amazon Kindle Fire HD 6 Tablet - 16GB
What do i do when i dont know how to register my kindle fire 1st generation
Contact www.amazon.com Next to the search bar you'll see Your Account. click, choose Your account from the list and click. Next page, far right column you will find help desk options. follow that to leave a message for them. They can send an email with instructions or call you back and walk you through it.
Aug 02, 2014 | Amazon D01400 Kindle Fire 1st Gen 8GB WiFi...
Sep 27, 2012 | Amazon Kindle Fire HD
Amazon Kindle 3G Logo
143 people viewed this question
Top Amazon Tablets & eReaders Experts
Jax Planet
Jax Planet
Sheldon Dedek
matt
matt
Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
