Question about Amazon Kindle Touch Screen Wi-fi W/ Special Offers - Pre-order
How to get connected to wi fi - Amazon Kindle Touch Screen Wi-fi W/ Special Offers - Pre-order
Posted by Paula Moore on
Scott Fryer
    Scholar:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 106 Answers
My monther's issue was because her ISP's (Bell) router, home hub 3000, comes default with the 2.4G and 5G SSID named the same with the same password. So her 2.4G was on a Band that was super weak, like 30%, but her 5G was at 90%. This was causing her wifi connections to use 5G as it was more available. Problem with the kindle is that it is limited to use the 1 - 11 channels / 2.4G only. I resolved this by going to the routers config (192.168.2.1) and changing the SSID from Bell553 to Foxtrot. Then i changed the 5G SSID to Foxtrox-5G and made different passwords for both. Rebooted the router and the kindle was able to connect to the 2.4G network.
Posted on Jan 09, 2017
Marvin
    Top Expert:
  • Amazon Master
  • 85,239 Answers
To connect to a Wi-Fi network with a hidden SSID, select Add Wi-Fi network from the settings. Then manually type in your SSID and password, and select your network security type. Select Save when finished. Now you can browse the web through your Wi-Fi router or connect to other network devices
Posted on Sep 28, 2016
Zte tablet model k88 wont connect to wifi
Weak wifi signal or defective tablet or router.
Jun 27, 2017 | Tablets & eReaders
How do I change the password on the kindle for the wireless network?
To add a new Wi-Fi Network:
If you don't see the network you want to connect to in the list of detected networks, you can add it by choosing "Enter other Wi-Fi network" at the bottom of the list of detected networks.
  1. Make sure you are within range of the network you want to add, and that you know the network name and password (if required).
  2. Press the Home button, then press the Menu button.
  3. Navigate to "Settings" by moving the 5-way controller down, then press the 5-way controller to select.
  4. Select "view" next to "Wi-Fi Settings" to display a list of detected Wi-Fi networks.
  5. Use the 5-way controller to navigate down to "Enter other Wi-Fi network" and press to select.
  6. Enter the name of the Wi-Fi network that you want to add.
  7. Enter the password (if required). Press the Symbol key to enter numbers or characters not present on the Kindle keyboard. You can continue to use the keyboard while the Symbol menu is displayed.
  8. Choose "submit." Kindle connects to the new Wi-Fi network.
If your Kindle fails to connect to the new Wi-Fi network, it will display an "unable to connect" message. You can try manually entering all the network information for the Wi-Fi network by choosing "set up network" when you see the "unable to connect" message. If you don't know the network information, try connecting to a different network, or contact the network's administrator.
To forget a Wi-Fi network:
You can tell Kindle to forget the Wi-Fi network you're connected to so that your Kindle doesn't connect to it automatically in the future.
  1. While connected to the network that you want to forget, press the Home button, then press the Menu button.
  2. Navigate to "Settings" by moving the 5-way controller down, then press the 5-way controller to select.
  3. Select "view" next to "Wi-Fi Settings" to display a list of detected Wi-Fi networks. You may have to wait a moment as your Kindle detects networks in range. The Wi-Fi network you are currently connected to displays the word "forget" next to it in the list of available networks.
  4. Choose "forget" to disconnect from the network.
To connect to a Wi-Fi network:
  1. Press the Home button, then press the Menu button.
  3. Select "view" next to "Wi-Fi Settings" to display a list of detected Wi-Fi networks. You may have to wait a moment as your Kindle detects networks in range. Kindle automatically scans for available Wi-Fi networks at periodic intervals. To rescan for available networks at any time, select "rescan."
  4. Select "connect" to connect to a network. If you see a lock symbol next to "connect," the network requires a password to connect.
  5. If necessary, enter the Wi-Fi network password, and choose "submit." Press the Symbol key to enter numbers or characters not present on the Kindle keyboard.
Once you are connected to a Wi-Fi network, Kindle automatically connects to it again whenever that network is in range. If more than one previously used network is in range, your Kindle automatically connects to the network that was most recently used.
Tip: Once your Kindle connects to a Wi-Fi network, that network displays "forget" next to it in the list of available networks. Selecting "forget" disconnects your Kindle from that Wi-Fi network and also prevents Kindle from automatically connecting to it in the future.
Mar 07, 2016 | Tablets & eReaders
How do I set password on Wi-Fi orca android tablet
Answer Line: Change your Wi-Fi password on various ...
www.pcworld.com/.../change-your-wi-fi-password-on-various-...
PC WorldFeb 11, 2013 - But Wi-Fi passwords, like every other kind, need to be changed every so often. Here's how to ... Android. You can't simply change the password here; you'll have to delete the network from your phone or tablet and recreate it.Missing: orca
How to Connect Your Android Tablet to a Wi-Fi Network ...
www.dummies.com/.../how-to-connect-your-android-tablet-to-a-wifi-net...
After you've activated the Android tablet's Wi-Fi radio, you can connect to an ... ... Be careful when connecting to a non-password-protected network. It's possible ...Missing: orca
How do i change my wifi password [Solved] - WiFi - Cell Phone ...
Dec 14, 2015 | RCA 8" Android Tablet w/Dual Tuner
Ok I asked the question three days ago why can I get on a free wifi connection with my phone but not my tablet
The free Wi Fi router may have run out of IP leases on its DHCP server just when you were trying to connect the tablet. If the leases are as an example say one week long then if lots of people connect to the free wi fi they get a lease for one week. So if the device comes back within the week it already has an IP address assigned to it and works. If a new device comes along it has to ask the DHCP server via the WI FI to assign it an IP address. If all available IP addresses are leased from the WI FI router the device will not get assigned an ip address. Would suggest trying to connect the Tablet on another Wi FI system to test it works.
I had this happen on my mobile phone when I was in Surfers Paradise in a Coffee shop and suspected the lease time on the WI FI router was too long for the amount of short term customers using the coffee shop. (the staff had no idea on why the Wi FI was not working so it would have been pointless to try and explain this concept to them and how to change the lease time on the dhcp server) Also there is a limit to the simultaneous number of users on a Wi Fi frequency on one access point . Unless the WI FI uses multiple WI FI access points.
Jan 27, 2015 | Mach Speed Trio Stealth G2 Tablet -...
How do get wi-fy on my tablet?
It's a good idea to access Wi-Fi whenever possible to avoid data charges. After you've activated the Android tablet's Wi-Fi radio, you can connect to an available wireless network. Obey these steps:
  1. Open the Settings app.
  2. Choose Wi-Fi.On some Samsung tablets, you find the Wi-Fi item on the Connections tab. Choose Wi-Fi to view a list of available Wi-Fi networks on the right side of the screen. Otherwise, the list shows up full screen.
  3. Choose a wireless network from the list.When no wireless networks are listed, you're sort of out of luck regarding Wi-Fi access from your current location.
  4. If prompted, type the network password.
    Touch the Show Password check box so that you can see what you're typing; some of those network passwords can be long.
  5. Touch the Connect button.
    The network is connected immediately. If not, try the password again.
When the tablet is connected to a wireless network, you see the Wi-Fi Connected status icon. This icon indicates that the tablet's Wi-Fi is on, connected, and communicating with a Wi-Fi network.
Some wireless networks don't broadcast their names, which adds security but also makes connecting more difficult. In those cases, touch the Add icon. This icon might also be labeled Add Wi-Fi or Manually Connect. To make the connection, type the network name, or SSID, and choose the type of security.
You also need the password, if one is used. You can obtain this information from the girl with the pink hair who sold you coffee or from whoever is in charge of the wireless network at your location.
  • Not every wireless network has a password. Still:
  • Be careful when connecting to a non-password-protected network. It's possible that the Bad Guys can monitor such a network, stealing passwords and other information.
  • Some public networks are open to anyone, but you have to use the web browser app to find a login web page that lets you access the network: Simply browse to any page on the Internet, and the login web page shows up.
  • The Android tablet automatically remembers every Wi-Fi network it has ever been connected to and automatically reconnects upon finding the same network again.
  • To disconnect from a Wi-Fi network, simply turn off Wi-Fi.
  • Use Wi-Fi whenever you plan to remain in one location for a while. Unlike a mobile data network, a Wi-Fi network's broadcast signal has a limited range. If you wander too far away, your tablet loses the signal and is disconnected.
Oct 29, 2014 | Nextbook Premium 8 Se Android
Cant get wi fi signal.
Solution 1.Check wireless connection.
The first step of diagnosis have to any other device connected to the same network, ensure the wireless connection is working fine, or verify the settings of your wireless router to correct it.
2.Check your Keep Wi-Fi on during sleep Settings.
Owing to Wi-Fi sleep policy your Wi-Fi connection may be going to get disconnected every now and then.
Tweak this policy to keep your Wi-Fi connection awake.
[Settings] >>[Wi-Fi]>>[Advanced]>> Check [Always] to keep the Wi-Fi on during sleep.
Save changes and exit all the screens. Your Wi-Fi will never get disconnected again due to this policy.
3.Check signal strength of wireless connection.
The performance of a wireless network connection depends in part on signal strength.
You have to connect the Wireless network where the signal strength is strong.
Check Wireless network signal strength icons in notification bar.
4.Try to turn off/on Wi-Fi on the device.
First to turn off Wi-Fi, [Settings]>>[Wi-Fi] >>[turn Wi-Fi to off].
And then to turn on Wi-Fi, [Settings]>>[Wi-Fi]>>[turn Wi-Fi to on].
5.Try to forget network on the device.
Forgetting wireless networks allow your tablet/phone to reset some settings.
[Settings]>>[Wi-Fi]>>Press & hold your[Net Work Name(SSID)]for 2 seconds.
>>Select[Forget Network]>>Re-Connect your wireless networks if it's disconnected.
6.Try to reboot your device.
7.Make sure your firmware is up-to-date.
>>Select[Settings]>>[About tablet]>>[System Firmware Update]>>[Check Update].
8.Try to reset your device.
Note: once RESET was performed, all data, apps, settings and personal information will be deleted after initialization.
Third-party programs might be the major probability of Tablet/Phone instable, suggested to have a full reset for the device if the situation persists.
[Settings]>>[Backup&reset]>>[Factory data reset]
9.Try to other wireless connections.
If steps above were not able to solve internet connection problem still, please try other wireless connections if available, otherwise contact your networking provider to technical support.
Oct 09, 2014 | Worryfree Gadgets 7inch Zeepad 7.0 Android...
How to tune in kindle to wi fi?
From the Home screen, press the Menu button.
Select Settings, and then select view next to Wi-Fi Settings.
In the list of detected networks, choose a network to connect to it.
If your Wi-Fi network and router support WPS (Wi-Fi Protected Setup), your Kindle will detect it.
If you don't see your network in the list, you need to add the network manually.
If the network is protected by a password or WPS (Wi-Fi Protected Setup), enter the password and then select Submit.If you don't know the Wi-Fi network password, contact the person who set up the Wi-Fi network.After you connect to a Wi-Fi network, your Kindle automatically connects to it again whenever that network is in range. If more than one network is in range, your Kindle automatically connects to the last network used.
Aug 16, 2014 | Amazon Kindle Fire HD
How do I connect my Samsung Galaxy to BT broadband?
Are you trying to connect via wi-fi or via bluetooth? Typical hotspots are wi-fi, and that can be as easy as turning on wi-fi (in Settings, Wi-fi - see manual or quick setup brochure) then waiting for it to find an active hotspot and plugging in any necessary password. Bluetooth is much less common. Post more info and I'll try to help more.
Jul 18, 2014 | Samsung Galaxy Tab Tablet PC
I can not or do not have a password for the sky wifi how do i get it
If the sky wi-fi is your own wi-fi service then the password is normally on a typed label stuck to the wi-fi router itself along with the SSID of the wi-fi network which should be the same as you have selected on the Kindle in confirmation you are connecting to the correct network.
If the sky wi-fi is not your own wi-fi then you will either need to contact the owner or administrator of that network or select a different wi-fi network to connect to as described in the Kindle Support web pages for your device.
Dec 27, 2011 | Amazon Kindle Wireless Reading Device
Amazon Kindle Touch Screen Wi-fi W/ Special Offers - Pre-order Logo
Top Amazon Tablets & eReaders Experts
Jax Planet
Jax Planet
Sheldon Dedek
rostit
Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
