Posted on Jul 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
PAPER JAM LIGHT IS ON - AND I CANNOT PRINT TO THE PRINTER. THERE WAS A PIECE OF PAPER JAMMED, AND I TOOK IT OUT. THE LIGHT IS STILL ON. I HAVE AIR DUSTED THE MACHINE AND EVEN PUT A NEW PRINT CARTRIDGE IN THE MACHINE. STILL HAVE A PAPER JAM LIGHT.
Anonymous
Level 2:
  • Expert 96 Answers
  • Posted on Jul 09, 2009
Anonymous
Expert
Level 2:
Answers
96
Questions
0
Helped
37580
Points
219
There is still paper caught under to paper guides or under the rollers you just have to use a flash light and manually turn the gears to see it
3helpful
2answers
Please help with cannon PIXMA MP150 printer problem, when trying to print, It reads that paper is jammed but I've checked several times and no paper is jammed. Printer will not print due to this...
Hello and Welcome to FixYa!
Paper jam means their may be small bit paper jam in side
, actually there are some "micro sensors" that detect a paper jam. There will be tiny piece of paper inside those sensors, thus tripping the sensor and paper jammed keeps coming up.
To solve this first of all Open printer cover and check to make sure no paper or foreign objects obstructing the printer feeder
, If you become sure that now really there is no paper, dust or foreign objects then Turn the printer off, and disconnect the AC power-cable. Open the printer cover & now give the printer a "blow-job" by compressed air.
If still problem exist then best & final option is to just contact to any Canon Printers service provider.
I hope this solution helps you
Thank you for using FixYa!
1helpful
I have a problem. When I turn on my printer, the first symbol from top constantly blinks and it doesn't print anything. How can I solve this issue?
Welcome to FixYa!
If the first symbol on the top is constantly blinking as shown in the picture below, It means that a paper or a foreign object has jammed your printer.
Jam can occur in 3 areas. Please refer to the image below.
1. Internal Areas
2. Input Trays
3. The Output Bins
To clear the jam, turn the printer off and disconnect the power cord. Be careful not to tear the paper in case of a paper jam. If a small piece of paper remains in the printer, it could cause additional paper jam.
Let's clear out the Internal Areas first. Push the button to open the print-cartridge door, and then remove the print cartridge. To prevent damage, do not expose the print cartridge to light. Cover it with a piece of paper. Please refer to the image below.
If jammed paper is visible, grasp it with both hands and slowly pull it out of the printer. Please refer to the image below.
If no paper was jammed inside the print-cartridge door, open the Output Bin or the back door
of the printer. To avoid damaging the printer, do not attempt to clear a jam in the top output bin by pulling the paper straight out.
Again, if jammed paper is visible, grasp it with both hands and slowly pull it out of the printer.
If no paper or foreign object is visible, close the back door of the printer.
Next, let's take a look at the Input Tray. (We have already taken out the print cartridge.)
Lift the Tray 1 roller cover, grasp the jammed paper or foreign object, and slowly pull it out of the printer. Please refer to the image below.
If no jammed paper is or foreign object is visible, open Tray 2 and see if a paper is visible. Again remove it slowly with both hands. Please refer to the image below.
Close Tray 2.
If no jammed paper is visible in the second tray area, pull down the upper media guide (we have already taken out the print cartridge). With both hands, grasp the jammed paper and slowly pull it out of the printer. Please refer to the image below.
Close the upper media guide and return back the print cartridge. Please refer to the image below.
These steps should clear out any jams that you are experiencing.
Connect back the power cord again and turn on your printer. You should be able to print now.
Thanks for using FixYa. Keep me posted.
Jas247
My printer got jammed with the paper. i took the paper out and clicked print again. the printer is still not printing. i restarted my computer but it still doesn't work. what do i do??
Power off your printers and remove the cartidge and power on.the printer will re-alligned itself and check if it work.If even some small piece of paper is stuck inside the printer roller,it will still give you paper jam message.If that is the case try to print test print from the printer itself.
1helpful
2answers
HP Photosmart C6280 paper jam--won't print (of course), message reads 'add paper to main tray'
Please try this to clear the paper jam
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
E-04 Clear Paper Jam, no paper in printer
alternative :
Jamming problem
try this
alternative :
1helpful
Paper jam
try this....
try this, its probably a small part of jammed paper or then theres a problem with the pickup, try cleaning it.
alternative :
Yellow light on and won't print on Dell model 1110 Lazer Printer
Dell printers are the worst I have worked with, this problem may be a 'paper jam' when there is no paper jam at all (or one REALLY stuck on the fuser). Check on the back of the printer for a piece of paper jammed on a sensor.
Paper Jam
try this
alternative :
Paper jam
hey, give this a shot
alternative :
k24674
ADMIN Andrew
ADMIN Andrew
