20 Most Recent HP LaserJet 1000 Printer Questions & Answers
Cleaned the paper pickup unit gear & sensor, your problem will solve.
Thanks.
HP LaserJet 1000... | Answered on Sep 05, 2019
when you had to remove the toner cartridge from the machine did you blow the machine ? if so did you remove the laser unit from the machine ? if yes , then check the shutter of the laser unit if it is opening
HP LaserJet 1000... | Answered on Mar 11, 2015
http://h20564.www2.hp.com/hpsc/doc/public/display?docId=emr_na-c03528329
HP LaserJet 1000... | Answered on Jan 30, 2015
The HP laserjet 1000 takes either the C7115A or C7115X cartridge. The common name is a 15A or 15X. If you have anything else - forget it, it won't fit. If you have a new/refilled one that does not work properly - make sure you have removed the seal tape or return to supplier.
HP LaserJet 1000... | Answered on Jan 05, 2015
nothing
HP LaserJet 1000... | Answered on Mar 09, 2014
the white ghost lines are down to the charge wire within the toner cartridge being dirty, the only real way forward is to replace the toner cartridge as access to the charge chorona wire is not possible without ruining the cartridge itself
HP LaserJet 1000... | Answered on Jan 09, 2014
download the drivers for HP 1200 or the generic drivers but the 1200 series should work
HP LaserJet 1000... | Answered on Jan 04, 2014
Describe the prob clearly..
HP LaserJet 1000... | Answered on Nov 24, 2013
what's the problem Madam ?
you can try to load the driver from the cd or from hp.com directly.
HP LaserJet 1000... | Answered on Nov 13, 2013
What is the problem with the windows 7 driver, does it not print or detect the printer. if it does not print, try to delete the driver and reload from the cd or from the hp.com website. if it does not detect the printer, try replacing the usb cable or let a technician look at the formatter board of the printer.
A worn fuser will cause a mirror image or duplicate image to appear on the page. Fusing assemblies can be purchased alone or as part of a maintenance kit.
HP LaserJet 1000... | Answered on Nov 02, 2013
How to print document with mirror printing?
HP LaserJet 1000 Printer Logo
229 questions posted
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
View Most Popular
LaserJet HP
  • LaserJet HP
Most Popular Question
hp laserjet 1000 printer
  • Office Equipment & Supplies
