SOURCE: epson stylus office bx300f
Usually this indicates that there's a problem with one of the following:
Best thing to do is try removing the cartridges, clean the cartridges gently with a cotton bud or similar, then replace them.. And to check the movement of the printhead to see if there are any indications of halted movement, etc...
If all else fails you will need to contact an Epson service engineer to try and get some help.
Best of luck and hope this resolves your issue.
SOURCE: epson bx300f installation
here it is-please vote your rating
http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=YZnBT5wk60aVKZQrD1EvP7U002FNsqU002FMgplS&tc=6
SOURCE: How do I change the a discharged cartridge in the
pree menu on the printer > go to maintenance > go to ink cartridge > press ok > open the lid > the cartridge will be in installing position, pull and relaese the lock > pull the cartridge u want to change using the clip provided. > undo the plastic pack of the new cartridge, tear open the vaccum pack, pull out the yellow tape > keep the cartrigdge on the hoder straight and gently press the top until u hear it click ! !!
SOURCE: Epson BX300F display shows priner error see
Epson BX300F display shows priner error see...please help my
