20 Most Recent Epson Stylus Photo R340 InkJet Printer Questions & Answers
I had the same problem with an Epson R340 printer and Epson Print CD software after installing Leopard.  Here's what I did.  Go to System Preferences.  Select Print & Fax.  Select the "+" box on the lower left part of the screen.  Select Epson Printer  -- USB and click "Add" and "continue" in the box that comes up (if it does). Now see if Epson Print CD will print to a CD.  If it does, great.  You can now actually go back to System Preferences and Print & Fax and delete the printer you just added by clicking on the "-" box and Epson Print CD will still work.  Now I found another problem with printing. The CD printing is now off center to the right and down, so in Epson Print CD program you have to click on print and from the print screen click on "Position Adjustment" in the bottom left corner.  I've found the perfect position is 3.5 mm up and 3.5 mm left to make everything print perfectly.  Good luck.
Epson Stylus... | Answered on Nov 16, 2019
Was it working fine before. If so then
click start -> run -> type "msconfig"
select "Normal startup"
click apply and Ok
and then restart the computer
Epson Stylus... | Answered on Sep 27, 2019
Epson printers will not print if one of the cartridges is empty. :(
Epson Stylus... | Answered on May 08, 2019
if you have a router, you can sometimes look at "network" setting and see all clients. Or you can ping 192.168.1.2-30 and see what returns a pong, that will tell you what is out there and maybe you can deduce its IP from the known ones.
Epson Stylus... | Answered on Oct 03, 2015
Sounds like bad ink. The only other thing that I can suggest is that maybe you should check your settings, and do a page align, as you would when changing the cartridge.
Thank you for contacting Fixya. Does this help? Let us know.
Ponder/Meditate/Pray for Peace.
Mary Oliveau { hugs }
Epson Stylus... | Answered on Feb 15, 2014
It sounds like your printer needs a cartridge alignment. This can be done through your printer software. If that doesn't work, it needs a new cartridge.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Epson Stylus... | Answered on Feb 25, 2013
Please follow the steps below to hard reset the printer and let me know the result.
1.Remove all the cables from the printer.
2.Wait for 10 mins.
3.Connect only the power cord and try to power on the printer.
4.If the problem is solved, then connect all other cables, otherwise let me know.
Epson Stylus... | Answered on Aug 29, 2012
clean printer head
Epson Stylus... | Answered on Jan 07, 2012
i have manual do you want ?
Epson Stylus Photo R340 InkJet Printer Logo
119 questions posted
Top Epson Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Stylus Epson
  • Stylus Epson
Most Popular Question
printer won 39 t print using black ink
  • Office Equipment & Supplies
