20 Most Recent Epson PowerLite S12 SVGA 800 x 600 LCD projector - 2800 ANSI lumens Questions & Answers
2answers
Epson 9000 Printer. Error Code 15 please?
Error code 15 on an Epson SureColor P9000 Commercial Edition Printer typically indicates a communication error between the printer and the computer or other device it's connected to. Here are some steps you can take to troubleshoot this issue:
  1. Check the connections: Ensure that all cables and cords are securely plugged in and not damaged.
  2. Restart the printer and computer: Turn off the printer and computer, unplug them, wait for a few minutes, and then plug them back in and turn them on.
  3. Check the printer driver: Make sure that the printer driver is installed and up to date. You can download the latest driver from Epson's website.
  4. Check the printer settings: Make sure that the printer settings are configured correctly, including the connection type and communication protocol.
  5. Reset the printer: Try resetting the printer to its default settings. You can find instructions for doing this in the printer's user manual.
If none of these steps resolves the issue, you may need to contact Epson support for further assistance.
3/15/2023 8:22:57 PM • Epson Office... • Answered on Mar 15, 2023
How to adjust UTC time in EPSON LQ- 300+ course recorder?
You would set it in the device running it. The printer is just that that, a printer. for instance, the Northrop Grumman Auto Pilot system. Epson LQ-300+ printer is used as a course recorder on board ship which has Northrop Grumman Auto Pilot system. When this printer is switched on, the head moves to the right and remains there. It does not print the course of the vessel.
3/11/2023 3:59:15 AM • Epson Office... • Answered on Mar 11, 2023
2answers
What does the Epson error code 0xf1 mean?
The Epson error code 0xf1 is an ink cartridge error. It means that the printer cannot recognize one or more of the ink cartridges installed in it.
3/10/2023 7:05:43 AM • Epson Office... • Answered on Mar 10, 2023
Hi there again. Epson lx350.i replaced main board only to find out later the one pin not working is actually in a fired position until when I switch machine off is when the pin goes back.please assist
If I understand correctly, you are saying that after replacing the main board in your Epson LX350 printer, you have found that one of the pins is not functioning properly and it only resets when you switch the machine off. In this case, it's possible that there is an issue with the connection between the pin and the main board or the pin itself may be damaged. Here are some steps you can take to troubleshoot the issue: Check the connection between the pin and the main board. Make sure that the pin is securely connected to the main board and that there are no loose connections. Inspect the pin itself for any physical damage or signs of wear and tear. If the pin is damaged, it may need to be replaced. Check if the pin is properly aligned with the other pins on the main board. If it is misaligned, this could cause the issue you are experiencing. Check if there are any firmware or software updates available for your printer. Sometimes, updating the firmware or software can fix hardware issues. If none of these steps resolve the issue, you may need to contact Epson support for further assistance or consider consulting a professional technician to diagnose and fix the problem.
3/3/2023 5:21:58 AM • Epson Office... • Answered on Mar 03, 2023
How do I access the waste ink tank/pads for an Epson Stylus DX8450 printer
The waste ink tank/pads for an Epson Stylus DX8450 printer are located at the bottom of the printer's housing, beneath the print head. Here are the steps to access and replace the waste ink tank/pads:
  1. Turn off the printer and unplug it from the power source.
  2. Open the printer cover to access the ink cartridges.
  3. Gently push the print head to the right to move it to the ink cartridge replacement position.
  4. Look for the waste ink tank/pads at the bottom of the printer housing, just beneath the print head. They may be covered by a small plastic panel.
  5. Remove the plastic panel, if present, by gently pulling it toward you.
  6. Use tweezers or gloves to carefully remove the old waste ink tank/pads from the printer.
  7. Replace the old waste ink tank/pads with a new one, making sure they are seated properly.
  8. Replace the plastic panel, if present.
  9. Push the print head back to its original position.
  10. Close the printer cover.
  11. Plug the printer back into the power source and turn it on.
  12. Reset the waste ink counter by following the instructions in your printer manual or by using a reset utility program.
It's important to note that replacing the waste ink tank/pads can be a messy and complicated process, and it may be best to have it done by a qualified technician or Epson service center to avoid damaging your printer or causing a mess.
3/3/2023 5:01:55 AM • Epson Office... • Answered on Mar 03, 2023
Issue with cord from power button to printer not connected Epson SC p600 dtg mod
I'm sorry to hear that you're experiencing an issue with the power button cord on your Epson SC P600 DTG mod. To address this issue, you'll need to locate the cord and make sure it is properly connected. Follow these steps to troubleshoot the problem:
  2. Check the cord connection on both ends. Make sure it is firmly attached to the power button and the printer head or board.
  3. If the cord is loose, carefully reattach it to both ends.
  4. Plug in the printer and turn it on to test if the issue has been resolved.
If the problem persists after following these steps, it may be necessary to seek assistance from a professional technician or the manufacturer.
3/1/2023 4:51:27 AM • Epson Office... • Answered on Mar 01, 2023
How Do I Fix My Epson Printer is an Error State?
Check this Solution:- Solution 1: Resolve all the Hardware Issues: Issues in your Epson printer hardware are one of the prime reasons that can force the printer to enter into an error state. If you want to resolve the problem, then the steps are given below.
  • Verify and check whether the printer's power cord is attached to the electrical socket properly. If not, then plug it in properly.
  • When the system is connected to the printer with the help of a USB cable, check whether the cable is in proper working condition. If it is somehow torn or broken, replace it with a new one.
  • If your printer is wireless, then verify and check whether the device is properly connected to the wireless network.
After finishing all the above steps, perform a test and print any of your documents on a fresh blank sheet of paper. If this solution doesn't work you can check the next one given below. Solution 2: Update the Printer Drivers: When you are using the latest version of the Operating System on your computer, then you should update the printer drivers as well. It is very much important to match the compatibility of both the devices as they will work simultaneously with each other. Update all the drivers of the printer at regular intervals. If you face any type of virus-related problems, scan your computer and remove them as well. Solution 3: Resolve with Windows Troubleshooter: Windows OS has a built-in troubleshooter that helps you to find any type of problem and fix it. When your Epson Printer in Error State, you can use this Troubleshooter tool and resolve the problem. The steps are here as follows.
  • Open the "Control Panel" and access the "Device Manager" and find out the place where the printer name list is present.
  • Click to expand the list and search for the name of your printer. After you see the icon, right-click on it and select "Troubleshoot".
  • This will open the troubleshooter window. Click on "Next" and start the process. Wait for some time until the procedure finishes.
After the completion of the troubleshooting process, you will be able to see the errors. Now, try to print and check whether the Epson printer in an error state Windows 10 persists or not. If the issue is still there, proceed to the next solution stated below. Solution 4: Check and Remove Jammed Papers: If any of these above solutions work, then you must be sure that there are issues within the printer device. One of the most common solutions is the paper jam that will make your printer enter into an error state. First, you must disassemble the printer, after that take out the jammed paper. Now, take a thin piece of cloth and clean the rollers and other delicate parts slowly and gently. Once you are all done, reassemble the printer and we hope that you will be able to print your documents. Hopefully, the above-stated methods will help you to fix the problem at once. If you want to know how to resolve other printer-related problems, then follow our website. Video:
2/28/2023 11:45:01 PM • Epson Office... • Answered on Feb 28, 2023
One pin of Epson lx350 not printing and have checked printer head and white cable are ok
If one pin of your Epson LX-350 printer is not printing even though you have checked the print head and the white cable, there are a few other things you can try to troubleshoot the issue:
  1. Clean the print head: Use a cleaning solution and a lint-free cloth to gently clean the print head. This can remove any buildup or debris that may be blocking the pin.
  2. Check the ink ribbon: Make sure the ink ribbon is correctly installed and not damaged. If it is damaged, replace it.
  3. Replace the pin: If the pin is damaged or broken, it will need to be replaced. Consult your printer manual or contact Epson customer support to find out how to order a replacement pin.
  4. Check the printer settings: Make sure the printer settings are configured correctly, especially the character set and print density.
  5. Check the software: If you are printing from a computer, make sure the software is configured correctly and the correct printer driver is installed. Try printing a test page to see if the problem persists.
If none of these steps resolve the issue, it may be a hardware problem that requires a professional technician to diagnose and fix.
2/28/2023 8:29:53 PM • Epson Office... • Answered on Feb 28, 2023
Epson wf2530 Error message:. See documentation. ON OFF light flashing adf FLASHING. Looked for paper jam and followed instructions no success
If you have already checked for paper jams and followed the instructions in the documentation without success, there are a few additional steps you can try:
  1. Turn off the printer and unplug it from the power source. Wait for a few minutes, then plug it back in and turn it on again.
  2. Make sure that the ink cartridges are properly installed and that they have ink in them. Replace any empty cartridges.
  3. Clean the printhead. On the printer control panel, go to Setup > Maintenance > Printhead Nozzle Check. Follow the instructions to print a nozzle check pattern. If the pattern is incomplete or has gaps, select Clean the Printhead.
  4. Reset the printer. On the printer control panel, go to Setup > Restore Default Settings > Reset All Settings. This will reset the printer to its factory default settings.
If none of these steps work, it may be necessary to contact Epson support for further assistance or repair options.
2/25/2023 9:25:48 AM • Epson Office... • Answered on Feb 25, 2023
Where excactly is the reset button for Epson L382?
The Epson L382 printer does not have a physical reset button. However, you can reset the printer by following these steps:
  2. Press and hold the "Stop" button, "B&W" button, and "Color" button all at the same time.
  3. While holding the buttons, plug the printer back into the power source.
  4. Continue to hold the buttons until the power light and the ink light start flashing simultaneously.
  5. Release the buttons and press the "Color" button to reset the printer.
The printer should now be reset and the error message should be cleared.
2/25/2023 9:22:39 AM • Epson Office... • Answered on Feb 25, 2023
I have an Epson XP-305 printer, after changing my ink cartridge i get a printer error E-01 and it tells me to turn off my printer.
The E-01 error on an Epson XP-305 printer indicates a paper jam or a mechanical issue with the printer. Here are some steps you can try to resolve the issue:
  2. Open the printer cover and remove any jammed paper or foreign objects. Check for any torn pieces of paper or debris that may be obstructing the printer carriage.
  3. Close the printer cover and plug the printer back in.
  4. Turn the printer on and see if the error message has cleared. If the error persists, try the following steps:
  5. Make sure the paper is loaded correctly in the printer tray and that the tray is not overloaded. Adjust the paper guides to fit the size of the paper you are using.
  6. Try resetting the printer by pressing and holding the Stop button for 3 seconds.
  7. If the problem persists, you may need to contact Epson support or a qualified technician for further assistance.
2/25/2023 9:21:55 AM • Epson Office... • Answered on Feb 25, 2023
How do i swap heads on epson stylus 4450 and 9400?
Swapping heads on Epson Stylus Pro 4450 and 9400 printers can be a complex and delicate process that requires a certain level of expertise and technical knowledge. It is recommended that this task be performed by a trained and certified Epson technician to avoid causing any damage to the printer or the print head. If you still want to proceed with swapping the heads yourself, it is important to follow the manufacturer's guidelines and safety precautions. The process generally involves the following steps: Power off the printer and unplug it from the power source. Remove the ink cartridges and any other components that may be in the way of the print head. Use a screwdriver to loosen the screws that secure the print head in place. Carefully remove the old print head from the printer, taking care not to damage any of the other components. Insert the new print head into the printer, making sure it is properly aligned and secured with the screws. Reinstall any components that were removed earlier, including the ink cartridges. Power on the printer and perform a test print to ensure everything is working properly. Keep in mind that swapping heads on your printer may void the warranty and can potentially cause irreparable damage. It is always best to seek professional assistance if you are not confident in your abilities to perform the task safely and correctly.
2/25/2023 9:20:59 AM • Epson Office... • Answered on Feb 25, 2023
Epson ds 530 gives a scanner error.see your documentation on the network adaptop. Even scanner scan slows, What to do?
The error message you are receiving on your Epson DS 530 scanner is related to the network adapter. Here are a few troubleshooting steps you can try:
  1. Check network connection: Make sure the scanner is properly connected to the network and the network settings are correct. Try restarting the scanner and the network router.
  2. Restart the scanner and computer: Restart the scanner and the computer and try scanning again.
  3. Update drivers: Check for any available updates for the scanner drivers and firmware. You can download the latest drivers and firmware from the Epson website.
  4. Check scanner settings: Check the scanner settings to make sure the correct scan settings are selected. Make sure the scanner is set to the correct mode, such as color or black and white.
  5. Try a different computer: If the scanner is connected to a network, try using a different computer to see if the issue is with the scanner or the computer.
If none of these steps resolve the issue, you may need to contact Epson support for further assistance.
2/25/2023 9:19:57 AM • Epson Office... • Answered on Feb 25, 2023
How Do I Install Epson Printer Driver on Ubuntu?
To install Epson printer driver on Ubuntu, you can follow these steps:
  1. Open the terminal on your Ubuntu system by pressing Ctrl + Alt + T.
  2. Run the following command to update the list of available packages:
sql sudo apt-get update
  1. Install the required packages for Epson printer drivers using the following command:
csharp sudo apt-get install printer-driver-escpr
  1. Connect your Epson printer to your Ubuntu system using a USB cable or connect it to your network.
  2. Go to the Printers settings by searching for "Printers" in the Activities menu or by navigating to Settings > Devices > Printers.
  3. Click on the "Add" button to add your Epson printer.
  4. Select your printer from the list of available printers and click on the "Forward" button.
  5. Ubuntu will detect the drivers for your Epson printer and install them automatically.
  6. Follow the prompts to complete the installation.
Once the installation is complete, you should be able to print from your Epson printer on Ubuntu.
2/25/2023 9:01:40 AM • Epson Office... • Answered on Feb 25, 2023
Epson EP 704A INKPAD ERROR
The Epson EP 704A inkpad error message is an indication that the printer's ink pads are saturated with ink and need to be replaced. The ink pads are responsible for absorbing and collecting the excess ink that is generated during the printing process. To resolve this issue, you will need to either replace the ink pads or have them reset by an authorized Epson service center. It is not recommended to continue using the printer without addressing the inkpad error, as it may result in further damage to the printer. You can contact Epson support or a local Epson service center for further assistance with resolving the inkpad error on your Epson EP 704A printer.
2/25/2023 8:59:45 AM • Epson Office... • Answered on Feb 25, 2023
I have an Epson R1900, this problem just started, it will print a line and advance the paper while printing but prints the same image or text on the next line, paper advance issue or a timing issue?
Based on the symptoms you described, it sounds like there may be a timing issue with your Epson R1900 printer. The erratic spacing and repeated printing of the same image or text on the next line suggest that the paper advance mechanism is not functioning properly. This could be caused by a number of factors, including a worn or damaged paper feed roller, a misaligned paper feed mechanism, or a malfunctioning sensor that controls the paper advance timing. To troubleshoot this issue, you can try the following steps:
  1. Check the paper feed roller for wear or damage. If it is worn or damaged, it may need to be replaced.
  2. Check that the paper is loaded correctly in the printer, and that it is not jammed or wrinkled.
  3. Check that the paper thickness setting in the printer driver matches the paper you are using.
  4. Clean the paper feed mechanism and paper feed roller with a soft, lint-free cloth.
  5. Reset the printer by turning it off, unplugging it from the power source, and leaving it unplugged for at least 10 minutes before plugging it back in and turning it on again.
If none of these steps resolve the issue, you may need to take your printer to a qualified technician for repair or replacement of faulty parts.
2/25/2023 8:58:27 AM • Epson Office... • Answered on Feb 25, 2023
Epson PowerLite S12 SVGA 800 x 600 LCD projector - 2800 ANSI lumens Logo
2 questions posted
Top Epson Office Equipment & Supplies Experts
Clive
Clive
Marvin
Marvin
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Epson Office Equipment & Supplies
Most Popular Question
access waste ink tank pads epson stylus
  • Office Equipment & Supplies
