If you don't have the proper watchmaker's tools (and you'll need several!) I recommend that you not do this yourself. You could scratch the case or damage the movement if you don't know what you're doing. If it's a water resistant watch the gasket also needs to be replaced once it is opened. DO NOT reuse a gasket! For about $8 any watch or jewelry store can change the battery and renew the gasket for you. Most Sears stores will do it while you shop.
this is a safety feature built in.. if you turn down the speed to fast to keep the motor from sticking and burning out, it cuts off.. if you do it slowly you will be fine unless you go too slow in which case it will happen again.
you have to stop the blade turning. Grip it with some locking pliers but it might damage the blade. Or jam it with a piece of wood/ stone and undo the nut.
It is solved by writing an equation If the shorter piece is y cm, then the the longer piece would be 4y which is four times the shorter length. The total of these 2 together is 2meters or 200 cm, Now write the equation (2 pieces together is 200cm)
y + 4y = 200 5y =200 y =40 Since we have taken the lengh of shorter piece as y, Shorter piece=40 cm OR 0.4m Longer piece =160cm OR 1.6m I have written the steps in detail for you to understand the process Good luck luciana44 Longer piece= 160cm
There should be a half sphere-like object on the bottom of the spool where the line goes. Twist counter clock-wise to remove. If it is a duel line trimmer then:
Cut two separate pieces of string, about 7 ft. each.
Stick the end of
the line in the hole on the inside of spool.
Wind clockwise onto spool,
putting the line that is closest to the ground on first.
Once you have
winded this piece on, lock the last 4 inches of line through the slits
on spool.
Repeat process for second piece of line, locking the last 4
inches in slot opposite the other locked in piece.
Put the spool on the
trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the
locked position.
If it is a single line trimmer: Then just wind a single piece of string clockwise onto spool. This may need to be longer than 7ft.
