20 Most Recent Mitsubishi WS-55711 55" Rear Projection Television Questions & Answers
If anything like the picture here it is a convergence problem--model indicated uses a single chip for this and it can be a do it yourself repair.
1. shop repair not needed--can be fixed in the home--average is around 200.
2. kits are available with instructions for around 100.
3. I have instructions for this repair (my own from doing hundreds of these sets--total parts cost averages under 30 dollars.
Getting at the parts and being able to solder is involved---the parts are all on the middle board in the set.
Let me know with a comment if questions or need more info.
SD TECH
This is the part that is bad in your set.
No two sets will look exactly the same but this is a convergence problem.
Mitsubishi... | Answered on May 01, 2012
sounds like power modules blown a capactitor or two or format board is overheating due to too much dust...remove cover panels and clean out dust from inside fans and circuit boards and try again....if this does not work may be the colour wheel or bulb
Mitsubishi... | Answered on Jan 15, 2012
Replace the dm poer board . its inside the metal box on the left (looking at the back with the back removed). p/n 935C986002
Or if you can solder then replace the 7 electrolytic capacitors on the DM power board. value 1000uf16v
Mitsubishi... | Answered on Aug 05, 2011
You may have a bad switch on the front control keyboard:
HAVE THE SET UNPLUGGED
1. Remove front speaker grill (it pulls off).
2. Remove inspection plate behind it.
3. Note the bundle of wires coming down from front keyboard, follow them inside and to the right where you will find 2 plugs in line, unplug both plugs: they are marked with letters and different so you cannot plug them back wrong.
4. With keyboard now unplugged try to operate the set with the remote (remote receiver is behind front screen).
5. If set now operates with keyboard out of circuit, you have two choices:
a) operate set with keyboard disconnected
b) remove entire screen unit to get at circuit board behind the buttons on front of set.
I have seen a lot of these sets with defective micro switches on that keyboard.
Before you rate this information let me know what you find and if you have any questions.
Mitsubishi... | Answered on Jul 20, 2011
Try unplugging the left side of the panel. May work, but you will have no blinking light - but the inputs can be changed (so you can use your DVD etc. extra stuff and the sound will work with the remote. Cheap way
Worth a try - or replace part (Expensive way) Good luck !
Mitsubishi... | Answered on Jul 07, 2011
I'm sorry to hear that because this will be a more difficult problem.
There are almost 50 capacitors in this set on the DM board, Format board, Power supply and the Terminal boards that have a tendency to go out of specs making this tv do many different "strange" things until the capacitors on the DM board go completely bad and the tv will simply sit flashing the green timer led and do nothing.
This has been called the "flashing green light of death"
Mitsubishi has offered a refurbishment service on some of these chassis' and we have heard several different prices - from $250 to $850... you may want to give Mitsubishi a call and see what they say.
If it's toward the high end, I don't believe you should invest more than $350.00 into the TV. There are new Mitsubishi 60" DLP TVs that can be purchased for less than $1,000.
If you have anyone that can solder and has electronics experience, and the ability to disassemble the set, you can check for the most commonly failing components.
I will say, however - this is an extremely complicated repair for the Do It Yourselfer- I would ONLY recommend opening up the chassis of this tv if you have someone with some electronic repair experience.
I hope I have given you helpful information.
Here is a thread you might also want to check out regarding the problems related to these sets.
http://www.hdtvmagazine.com/forum/viewtopic.php?t=11430
Take a look at the service manual and then decide if you want to jump in to this repair.
If you do not have someone very familiar with electronics, it would be worth having a Mitsubishi authorized technician do a diagnostic on the TV. There are some situations that would make this repair less than the $300.00 (depending on what is found).
Please let me know if you would like more information and/or clarification.
Mitsubishi... | Answered on Jun 17, 2011
jbrosal6200,
Before I tell you how much the 3 screens cost you should know that there is a known problem with this model Mitsubishi. I have a tip at
http://www.fixya.com/support/r7065906-mitsubishi_turn_flashing_power_timer
which explains the problem. You do not appear to have it yet but you should look at my tip bedore replacing the screen. I have a tip at
http://www.fixya.com/support/r6210638-replace_broken_projection_tv_screen
which explains the problem, how to correct it and where to get the parts.
Thanks for using FixYa and for the great rating.
hardrocko
Mitsubishi... | Answered on Mar 07, 2011
Will the TV tunr on using the front panel power switch?
Need to narow down the problem first. TV has IR receiver on the front panel to receive the signals from the remote, so it can be bad also.
Mitsubishi... | Answered on Mar 03, 2011
Look for a big heat sink (big piece of aluminum) right behind the back access panel. The brown pressboard that you need to take of to have access to the inside of the chassis. I think there is two STK chips for this tv. Older mits only had one. The STK chip is black, should be about 3" long with about 20 pins on it. It may have a metal clip covering the part number on the front.
Mitsubishi... | Answered on Feb 19, 2011
It is called convergence problem. Model indicated uses a single convergence chip for this. I will attach photo of the part; part on EBAY is well under 20 dollars.
Part is a STK-393-110.
The good news is I have start to finish, step by step instructions for the do it yourself person for this repair.
If you want the instructions which tell everything you will need and how to do the repair rate this solution as very helpful and let me know how to get them to you.
Mitsubishi... | Answered on Jan 20, 2011
Open up the front, look under the right side picture tube. Look for puddle of oil on signal board. If you see this, it has bad picture tube & signal board. Not a good repair.
Mitsubishi... | Answered on Jan 18, 2011
You mean something like this?
http://www.youtube.com/watch?v=YCSNWi3UHf4
http://www.youtube.com/watch?v=1gC3KRfQXwo
Mitsubishi... | Answered on Jan 13, 2011
Hi.
There is a service bulletin. The problem is usually caused by a defective DM power board. Before replacement, the power board must be tested. Rather than replacing the whole board, the repair job is done testing and replacing at component level.
Here from Mitsubishi Bulletin:
Chassis V21 (this TV): Check C9B01, C9B02, C9B03, C9B13, C9B14, C9B17 and C9B18 (1000 uFD, 16V, 105C) on the DM Power PCB located within the DM Assembly. If they are bad, replace them with part # 181P734030 (680 uFD, 16V, 105C).
Here Service Manual - Chassis V21
Here Tv Repair Kit (not necessarily the cure, parts must be tested, the repair involves testing and soldering and must be done by a trained person).
Regards.
Ginko.
Mitsubishi... | Answered on Sep 20, 2010
DM is no longer available from Mitsubishi.
Unit can be removed and sent our for repair----
PTS ELECTRONICS---you will find them on the web and you can call or email for a quote.
Usually there are some caps and or fuses that fail in the DM unit.
Did you try to disconnect front keyboard to make sure it is not the problem?
If this told you something you did not know rate this solution as very helpful as I do this for free.
SD TECH
Mitsubishi... | Answered on Sep 05, 2010
The microprocesser that controls your remote function is bad.
Mitsubishi... | Answered on Aug 18, 2010
Could be convergence. Check the error code by pressing menu and device together for 5 sec and the timer light will flash a code. If it flashes 2 times pause and 2 times again it is the convergence IC stk393-110 and 2 fuses. Goodluck.
Mitsubishi... | Answered on Jul 06, 2010
Mitsubishi WS-55711 55" Rear Projection Television Logo
55 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Mitsubishi Televison & Video
Most Popular Question
mitsubishi ws 55711 geting color shdows
  • Televison & Video
