You have could use a cable with 2 tulip plugs on one side and a 3,5 mm headphone plug on the other side. Plug the tulip plugs on the back of your Kenwood in AUX, tuner or Tape in, and choose thethat input on the Kenwood and plug the 3,5 mm plug in the headphone port of the MP3 player (iPod)
That is all.
From what i see it is a compact hi fi system. no do not connect to the headphone port. there are many ways to use this. on the back if it has an cd or phono imput, you can get a cord to go from your ipod to connect to this and use the system to play through. it is has pre amp inputs your ipod might be useable through them as well. the manual is on line in several places and here is a link to one. Kenwood NV 701 Instruction Manual
SOURCE: usb kdc-x890 IPOD
The 890 doesn't support iPod control via USB. You can only read plain data storage devices on the USB port, such as a flash drive or portable hard drive. When you plug the iPod in (to a PC or the 890), it doesn't show up as a plain file storage device. Some of the newer Kenwoods do offer direct iPod control via USB. These ones have more "smarts" and are able to properly talk to the iPod and access its music. For the older models, you'll need to buy the special iPod interface, which accesses the iPod like a CD changer.
SOURCE: IPOD connection port
it's on the back of the deck if you have the plug/adapter for it all you have to do is line up the plug, im pretty sure its on the passenger side of the deck
SOURCE: Cannot play ipod touch on car stereo
hi there
You will need one of theses:
Click Here
This is a USB to Stero adaptor... will fix your problem for you.
hope this helps
alex
SOURCE: Can;t play my Ipod through Kenwood KDC 237
i was just having this same problem but i pressed standby and menu and scrolled up till i got to a AUH which is off all i did was turn it on and press standby again and my ipod started playing
SOURCE: Connecting iPod to JVC KD-LH810!?!
Hi, KD-LH810 has no option for external input. Refer to the picture attached. It is only front and rear line outputs. Don't get disappointed. Buy the accessory cable KS-U100 and you are set. This info is from the installation manual.
