20 Most Recent
Kenwood KFC-HQ695 Car Speaker Questions & Answers
My Kenwood Excelon Kdc-x879- days rehabbed when I power it on why
It is possible that the Kenwood Excelon KDC-X879 has a fault with its power supply or internal components. If the unit has been recently rehabbed, it is possible that the rehab process did not go as planned and the unit is not functioning properly. If this is the case, it is recommended that you contact the company that performed the rehab to have them diagnose and repair the unit.
How can I get my Kenwood KRC-PS959R unstuck from eject mode
- Turn off the power to the unit: Unplug the power cable or disconnect the battery to turn off the power to the unit.
- Locate the reset button: Check the manual or the unit itself for a reset button. If you find it, press and hold it for a few seconds to reset the unit.
- Disconnect the battery: This may help to reset the unit and release it from eject mode.
- Check the tape mechanism: Make sure the tape mechanism is free of any debris or obstructions that may be causing it to get stuck.
If the above steps do not resolve the issue, it may be necessary to have the unit serviced by a professional repair technicia
Sparkomatic S8E7 Compact Equalizer Booster Install manual
To connect the Sparkomatic equalizer to your Kenwood head unit, follow these steps:
- Connect the RCA cables from the head unit's preamp outputs to the equalizer's inputs.
- Connect the RCA cables from the equalizer's outputs to the amplifier's inputs.
- Connect the equalizer's power and ground wires to the amplifier's power and ground wires.
- Turn on the head unit and equalizer, adjust the equalizer's settings as desired and enjoy improved sound quality.
Note: If your head unit does not have preamp outputs, you may need a line output converter or signal processor to connect the equalizer.
I have a kenwood head unit with 12 pin for a cd changer, I have connected a kenwood cd changer when I press the cd changer source on my head unit it's coming up aux ext but no changer options
It sounds like you're having trouble connecting your Kenwood CD changer to your head unit. Here are a few troubleshooting steps you can try to resolve the issue:
- Check the connections: Ensure that all the wiring connections are secure and properly connected to the head unit and CD changer.
- Reset the head unit: Disconnect the power to the head unit, wait a few minutes, and then reconnect it to see if the issue is resolved.
- Check the compatibility: Make sure that the CD changer you have connected is compatible with your head unit and the 12 pin interface.
- Update software: If your head unit has firmware or software updates available, it may be worth updating to see if the issue is resolved.
- Contact the manufacturer: If the above steps do not resolve the issue, it may be best to contact Kenwood's technical support for further assistance.
It's important to handle the head unit and CD changer carefully to avoid causing further damage or issues. If you are not familiar with the installation and connectivity of a CD changer, it may be best to seek help from a professional for a repair.
Kenwood A58 amplifier spectrum issue
It sounds like your Kenwood A58 amplifier may be having a technical issue that could be caused by several factors, including an internal component failure, a wiring problem, or a software issue. Here are a few suggestions to help resolve the issue:
- Check the wiring: Make sure that all the wiring and connections to the amplifier are secure and properly connected.
- Power reset: Disconnect the power to the amplifier, wait a few minutes, and then reconnect it to see if the issue is resolved.
- Update software: If your amplifier has firmware or software updates available, it may be worth updating to see if the issue is resolved.
It's important to handle the amplifier carefully to avoid causing further damage or issues. If you are not familiar with the internal workings of an amplifier, it may be best to seek help from a professional for a repair.
Why not show CD track info on Kenwood c-h7 using dp-mh5 player? what error ? what should check?
The issue with not showing CD track information on your Kenwood C-H7 using the DP-MH5 player could be caused by several factors. To resolve this issue, you can check the following:
- Compatibility: Ensure that the DP-MH5 player is compatible with the Kenwood C-H7 unit.
- CD format: Ensure that the CD is in the correct format and meets the requirements for playback on the DP-MH5 player.
- CD read error: Make sure the CD is clean and free of scratches, as these can cause read errors that prevent track information from being displayed.
- Connections: Check the connections between the DP-MH5 player and the Kenwood C-H7 unit to make sure they are secure and properly connected.
- Software/firmware: Make sure that both the DP-MH5 player and Kenwood C-H7 unit have the latest software/firmware installed and are up to date.
If these steps do not resolve the issue, you may need to seek further assistance from the manufacturer or a professional repair service.
Error code 99 Kenwood kdc-148
The manual simply says this is a malfunction and you are advised to press the reset button. If the error does not vanish the, you are advised by the manula to contact the service center.
I please need a kenwood
battery yellow
accessory red
ground black
power antenna blue
amp turn blue/white
illumination orange
dimmer orange/white
RF + gray
RF - gray/black
LF + white
LF - white/black
RR + violet
RR - violet/black
LR + green
LR - green/black
