What is the ideal setting for the fridge as there are no numbers on the temperature control knob.
Hello John;
My name is Peter. I am a retired Sears service technician. The freezer temperature should be between -2 & + 2 degrees F. The fresh food section should be between 35-40 degree F.
Pick up a inexpensive temperature gauge with a steel shank. Place the temperature gauge in the freezer center. Do not make contact with any food product. Allow 20 minutes and read the gauge. Be quick the temperature on the gauge will drop quickly when you remove. Adjust the temperature control knob according until you reach the desired setting. Repeat this process as necessary. Do the same for the fresh food section.
You only have one source of cooling; the evaporator coil and fan in the freezer. The freezer will meet it's temperature setting first before it opens the fresh food section damper.
A balanced system will save on your electrical bills. The compressor will kick in only when demand is met. Your compressor should not be running continuously.
SOURCE: My Bosch Fridge Freezer Model
Hi thanks for the question. I would pull fridge away from the wall . remove back panel . clean all coils . thanks the appliance doc
SOURCE: Fridge not getting cold Bosch KGV36390/05
Hi: It shouldn't need a recharge as your freezer is cold, and that's wher the fresh food section gets its cold from via a fan. If your vents are blocked with too much food in the freezer this will happen. If you have a problem with the defrost heater or timer frost will build and block the port to the fan, causing a warm fresh food section. If the circulating fan is out your f.f. section will get warm. It's a small fan not to be confused with the condenser fan below (at the grill.) Here's a question for you. Did the fresh food compartment work for the first week or two? That's how long it would take frost to build and jam the system if your defrost system is out. If this is the case you can unplug it and put your food in a cooler. Melt the frost with a hair dryer carefully avoiding plastic components. It will then work for a week or two before it fails again. It will get you buy until you get service. If you do it yourself... Look for the defrost heater in the freezer and see if the coil of wire in the glass tube is broken. You will need a service manuals or a parts list with a diagram. Sears parts on line has a good database of parts and diagrams. Hope this helped, Jeff
SOURCE: How to use temperature settings on Bosch Classixx fridge freezer
You can find most user manauls at, www.managemyhome.com, on the right side of the page. You will need the model number off the product information label affixed to the unit.
SOURCE: Temperature setting
The fridge should be just above freezing, maybe 2 or 3 degrees celsius. The freezer should be around -15 degrees celsius. The outside temp doesn't matter as far as the settings go.
SOURCE: i have a bosch fridge
Once the fridge is shut OFF for few hours to defrost and then switched ON , if the fridge works with cooling , then the fault is with the AUTO DEFROST TIMER or the circuit -maybe the heater, break in the lines to the timer, heater, the fan.
The build up frost will block the flow of cool air to the fridge from the freezer evaporator.
So remove and check.
