SOURCE: Deve Home sensor Error as occur cannot get printer to work
The web does not offer alot on this error. However the users manual indicates it is a fuser issue. Try a new maintenance kit. That should include the fuser and all rollers.
SOURCE: Deve home sensor error
hi if u check the samsung manual herehttp://www.wisconsinimaging.com/downloads/clx3160manual.pdfthen u will find it in page 79 and it saysThere is a problemin the fuser unit.suggestion:Unplug the powercord and plug it backin. If the problempersists, please callfor service.
SOURCE: deve home sensor error
This can be fixed by stretching out a solenoid spring on the power cord
side of the printer. The solenoid acts as a clutch to stop the spinning
developer actuator at the right spot.
Open up the right side (power cord side) of the printer (take off top
cover, then take off side cover). Then, find a solenoid (little metal
square) that touches the white plastic vertical spur gear. Take the
spring off the solenoid. Now, put the spring back on - only this time
you will attach one anchor point to the middle of the spring as to
pre-stretch the spring for more tension.
The problem is that the spring gets weak over time / the cogs round out
over time and the solenoid finger is overcome by the spinning cogs, and
resulting in selecting the wrong developer.
More pictures of the solenoid on Facebook:
http://www.facebook.com/#!/photo.php?pid=55779771&id=2257206&fbid=10100154259704133
SOURCE: non-working printer; no paper pickup
The solution shown for the Samsung CLX-3160FN All-In-One works also for the Samsung CLX-2160N.
The associated picture and methodology of "pre-stretching" the solenoid spring is virtually identical for both printers.
Worked for me on the CLX-2160N
See here
http://www.fixya.com/support/t4742967-deve_home_sensor_error
