On the 3175 there is no spring. I believe it is the fuser that causes the Deve home sensor error. There is a cam shaft that relieves the preasure of the fuser rolls. The cams get worn down so it does not relieve any preassure, I think this is root cause of the problem. It can be bought and replaced without buying a new fuser.
Dear
There is a problem in the fusser unit.Turn the power switch off and on. If the problem persists, call for service engineer.
Thanks.
SOURCE: Deve Home sensor Error as occur cannot get printer to work
The web does not offer alot on this error. However the users manual indicates it is a fuser issue. Try a new maintenance kit. That should include the fuser and all rollers.
SOURCE: i am getting deve home sensor error on my samsung
Dev. Home error can be fixed by stretching out a solenoid spring on the power cord
side of the printer. The solenoid acts as a clutch to stop the spinning
developer actuator at the right spot.
The problem is that the spring gets weak over time / the cogs round out
over time and the solenoid finger is overcome by the spinning cogs, and
resulting in selecting the wrong developer.
Open up the right side (power cord side) of the printer (take off top
cover, then take off side cover). Then, find a solenoid (little metal
square) that touches the white plastic vertical spur gear. Take the
spring off the solenoid. Now, put the spring back on - only this time
you will attach one anchor point to the middle of the spring as to
pre-stretch the spring for more tension.
More pictures of the solenoid on Facebook:
http://www.facebook.com/#!/photo.php?pid=55779771&id=2257206&fbid=10100154259704133
SOURCE: Deve home sensor error on samsung clx-3160fn printer
Dev. Home error can be fixed by stretching out a solenoid spring on the power cord side of the printer. The solenoid acts as a clutch to stop the spinning developer actuator at the right spot.
The problem is that the spring gets weak over time / the cogs round out over time and the solenoid finger is overcome by the spinning cogs, and resulting in selecting the wrong developer.
Open up the right side (power cord side) of the printer (take off top cover, then take off side cover). Then, find a solenoid (little metal square) that touches the white plastic vertical spur gear. Take the spring off the solenoid. Now, put the spring back on - only this time you will attach one anchor point to the middle of the spring as to pre-stretch the spring for more tension.
SOURCE: deve home sensor error
In fact, it happens that the release lever of the solenoid magnet is attached to the sponge on the base because it has aged and become sticky and then the lever is not released on time and the cam makes one revolution in an unusual way, every time you turn the cam approaching the gears of the drum and only runs the development team correspondent, but when the lever is released late in the development team does not run properly and the machine runs another cycle to align the colors until finding the right sequence, failing to align the colors in the right sequence stops giving the error
I can not take off top panel and I can not take off side cover. How to do?
Kaj
