Need ti know what the error codes are for Whirlpool Duet clothes washer , model number is WFW9200SQ02
Every one of these washers come with a technicial data sheet inside the unit. To access, you will need to remove the lower toe panel under the door. The panel comes off by locating and removing the screws under the bottom front edge of the washer. You may have to prop the front feet of the washer up for better access to the panel screws (a 2x4 works well for this). With the screws removed, the panel will dro down, then come off. The tech sheet will be located either directly behind the panel, or affixed to one of the interior cabinet walls. Included in the tech sheet are all the error code definitions, troubleshooting data, wiring diagrams and diagnostics procedures. I hope this helps you.
