20 Most Recent
Nokia C5 Cell Phone Questions & Answers
NOkia C5 in offline mode.
if you hold finger on the volume up button dial a box comes up on the bottom of the screen says do you want to stay offline you press no and the phone will reboots itself into normal mode
How dro ownload dictionary english to hindi
If at all possible, try to pay off your loan in full. Even if paying off an account in full won't harm your credit as much as not paying anything at all will, the "settled" status on your credit report is still seen negatively. So you are thinking about
how to apply for a dro online call us 03338803165 and we will show you right way to pay off your debt .
TRANSFER CONTACTS FROM NOKIA C5 TO IPHONE 5
You can just share contacts on Nokia to iPhone with email. Just follow below steps.
You can take advantage of Gmail (or other emails provide contacts sync function) to sync Nokia contacts to iPhone. The following tutorial will show you how to do it:
- Log in Gmail on your Nokia phone, and check the "Sync Contacts" option (If you are first time to use this method.
- After Gmail Contacts synced with your Nokia Contacts, you should turn to iPhone, and tap Settings > Mails, Contacts, Calendars, and tap Add Account. Then choose Google, and enter your Gmail account.
- After adding Google Account, you can turn on Contacts, and iPhone will ask whether you want to merge with your iPhone contacts. Click Yes and the contacts will be synced to your iPhone.
With the sync function of Gmail, people are able to transfer contacts from Nokia to iPhone with ease. If you aren't using Gmail on your iPhone, don't worry, you can take advantage of other email services like Yahoo, Outlook and so on.
For more methods, check:
How to Transfer Contacts from Android to iPhone
How to reset lock code
- To unlock you Nokia C5 (if forgot or lost lock code) you can unlock it using a master code. - To get the master code i need the IMEI code of your mobile phone. - With the help of this IMEI code we can get the master code of your mobile and unlock the mobile and reset it with a new password.
- The IMEI number can usually be found on the sticker underneath the battery or by typing *#06# into the phone keypad.
Hope this helps, please rate and leave a comment if the solution was helpful, thanks!
I hereby want to say that GPRS service is not
Even though it is not activated, one or few of your current applications dialing a data call over your network. If that is not the case, may be your service provider keeps reducing your account due to a problem of theirs.
Other than that, it may be an unwanted software which makes the call(I do not like to call this a virus)
I'd suggest you contact your service provider and talk with this.
