Error code 20
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
SOURCE: HP OFFICEJET 4215 cartridge error
Try this while standing on one leg.
1. OPen ink caridge lid.
2. Remove the affected cartridge.
3. Close lid
4. Try to print. This will fail, but that is ok.
5. Open the ink cartridge door again.
6. Remove the other cartridge.
7. Unplug the unit.
NOTE FOR THE NEXT STEP
This can be risky and I asume no responsibility for pressng too ******* the contact points, havng too much alcohol, using the wrong kind of alcohol, or not using alcohol or other such problems that can occur.
8. Using ONLY alcholo lightly brushthe contact points
9. Lightly clean the cartridge cotact points.
10. Plug in the unit
11. Install the cartridges.
12. Go through the alignment process.
13. Switch to the other leg, those with one leg only are exempt.
14. You just might be ready to print again.
I know this sounds crazy but this just worked for me.
Callan
SOURCE: Error message: "Door Open"
HI there,
Follow the steps below:
Step one: Close the print cartridge access door
1.Verify that the print cartridge access door is completely closed. It may appear to be closed, but if it is not completely closed, the error message will display. Verify that there are no obstructions blocking the door.
2.If you are unsure how to close the print cartridge access door on your model, consult your User Guide for more information.
Figure 1: Examples of closing the print cartridge access door (your model may vary)
If you have attempted to completely close the access door and the error still appears, there may be a problem with the door sensor and the unit may require service.
Step two: Service your product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Good Luck!!!
neo
SOURCE: error code i hp 4255 officejet printer
have problem in my printer hp officejet 4255 oll-in-one it give message ERROR : 0XF0aF8005 pleas help me I can repair the priter if u can diagnose the error code
SOURCE: ERROR :0xf0af8005
Solution one: Reset the product
Solution two: Service the product
