20 Most Recent HP OfficeJet 6700 Premium All-in-One Wireless Office Machine Questions & Answers
  1. Switch on the HP Officejet 6700 series printer and wait until the printer is READY. [The Power light should be on]
  2. Double click on OJ6700_R1435A.exe to launch the HP Printer Update utility. A list of OfficeJet 6700 Premium series printers detected will be displayed on the screen.
    Note: If the Wired network printer you wish to upgrade is not displayed in the detected printer list, click on the Refresh button to scan for printers connected via the wired network.
  3. Click on the checkboxes on the left to select single or multiple OfficeJet 6700 series printers you wish to upgrade.
  4. Click on the Update button to start the firmware flashing process.
  5. Message showing "The selected printer has been updated successfully" will be displayed. Firmware flashing will begin.
    CAUTION! Do not interrupt the printer during the upgrade process. Printer may be damaged if power is interrupted during the firmware upgrade process.
  6. When the printer has successfully completed the flashing process, it will automatically print out a Self Test Diagnostic Page, that will show the new firmware version.
  7. Click on the Done button to close the HP Printer Update utility.
HP Officejet 6700 Premium All in One Firmware
HP OfficeJet... | Answered on Nov 05, 2019
Try removing ink cartridge, check if the protective tape is removed from all of them and insert it back in and make sure it's aligned properly.
HP Office... | Answered on Sep 23, 2020
I guess I should ask if you used an HP replacement cartridge or another brand? The printer may not recognize a 3rd party replacement cartridge. Next, assuming you are using an HP cartridge, is it new or a refill? A refilled cartridge may have dried ink blocking the ejection ports on the cartridge.
So I would start with a reset of the printer. remove the ink cartridges. Disconnect the cables, and press the power button for 30 seconds. Then reconnect the cables, turn the unit on and reinsert the ink cartridges. Do a test print. If the black still doesn't work try cleaning the print head.
Click the setup icon and go to Printer Maintenance, click Clean Print Head. You should hear the machine doing this. Print a test page and see if this fixes the issue. If it doesn't or only partially fixes the problem wait 10 minutes and clean the print head again. Hopefully, this will at least improve the issue. If the print quality still doesn't look right wait 10 minutes and repeat the cleaning again.
Hopefully your issue is fixed. If it still isn't printing, could it be your paper? Is it the same paper you were using before? Some kinds of paper do not absorb ink very well.
Hope this helps.
HP Office... | Answered on Sep 22, 2020
Paper Jam or sticky solenoids. Open it up and remove the toner cartridge.
https://h30434.www3.hp.com/t5/LaserJet-Printing/HP-LaserJet-1320-Orange-Flashing-Light-manual-feed-problem/td-p/7002812#:~:text=It%20looks%20like%20that%20your,will%20never%20come%20back%20again.
HP Office... | Answered on Sep 17, 2020
see hp's website for manuals and instructions on how to
HP Office... | Answered on Sep 01, 2020
Connect your 123.hp.com/envy5660 printer after the printer hardware setup before you print or scan from a computer through a wireless network. Install the HP printer software from a wireless network from a computer with Windows 7 or later.
STEP 1 : BEFORE INSTALLATION
  • If you want to connect the printer 123 HP Envy 5660 Setup to your wireless network, make sure you know the network name and password.
  • Connect your Windows computer to the wireless network and make sure the HP printer is compatible with the wireless
  • Obtain the network name (SSID) and network passphrase (WEP key or WPA). A broadband internet access is must be used. Make sure you have the USB cable provided along with the printer package.
  • Turn on your printer, router, and computer and make sure the computer is connected to the same wireless network you want the printer to connect to.
  • If you have connected any USB cable to the printer, disconnect it before you proceed with the software installation.
  • Follow the instructions to remove the USB installation if it was previously setup on your computer before you continue:
  • Search for the HP folder in the list of installed software programs, click the HP printer folder, and then click 123.hp.com/envy5660
  • Once the HP Printer Assistant software opens, click Utilities -> 123.hp.com/setup 5660 & Software Selection.
  • Continue to follow the prompts and click Convert a USB connected printer to wireless or Connect a new printer.
  • To complete the software installation, follow the on-screen instructions.
  • You can also run HP Print and Scan Doctor, an automated tool to connect the printer to your wireless network.
STEP 2 : CONNECT TO THE WIRELESS NETWORK
Connect your 123.hp.com/envy5660 printer to the wireless network using the built-in Wireless Setup Wizard to identify network name and entering the network password.
  • If the printer is not turned on, press the Power button to turn it on.
  • On printer's control panel, touch the Wireless icon to preview the Wireless Summary screen.
  • On the Wireless Summary screen, touch the Settings icon and then touch Wireless Settings.
  • Under the Wireless Settings menu from 123.hp.com/setup 5660, select Wireless Setup Wizard and follow the on-screen instructions to complete the setup.
STEP 3: DOWNLOAD AND INSTALL HP PRINTER SOFTWARE
Download the supportive 123.hp.com/envy5660 printer software from our website once the printer is connected to your wireless network.
  • Turn on your HP printer and eject any USB cable if connected to the printer.
  • Go to our website and navigate to the download page where you have to download the printer software manually.
  • Select your printer model when prompted and then, follow the on-screen instructions to reach the download page.
  • Next, to the full feature, click Download or click Basic Drivers.
How to solve HP Printer issues 5X Faster Answer is inside
HP Office... | Answered on Aug 27, 2020
If your printer speed is slow try reset it.
Resetting the printer can resolve some types of slow printing issues. Click the link for the steps on how to reset Hp printer
HP Office... | Answered on Aug 25, 2020
Try updating the printer firmware and check if it helps. Reset the printer to clear certain error states by calibrating the scanner mechanism, and then check the power source to confirm the printer is getting enough power to operate the scanner. From:
https://h30434.www3.hp.com/t5/Scanning-Faxing-and-Copying/Hp-laserjet-pro-M275-camera-giving-camera-error-1000/td-p/6965213
https://support.hp.com/us-en/product/hp-topshot-laserjet-pro-m275-mfp/4346268/troubleshooting
HP Office... | Answered on Aug 24, 2020
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Locate the squeaking roller and spray the end with a little WD40
HP Office... | Answered on Aug 20, 2020
This sounds serious. Maybe you should get the experts in.
There are several error that could be in your Hp printer that's why your HP printer is unable to print such as paper jam, print jobs stuck in queue and other printing problems etc.
To troubleshoot HP printers Visit https://www.printeralign.com/fix-hp-printer-wont-print
HP Office... | Answered on Aug 11, 2020
This error (supply memory error) usually comes up when there is a bad contact between the cartridge's chip and the printer. Sometimes that chip becomes faulty. If you have replaced the corresponding cartridge and you still get the same error then you will have to look at the printer's side which makes the contact to that chip.
HP Office... | Answered on Jul 24, 2020
If you have already replaced the paper feed motor once then you are supposed to replace it again and also replace an additional part I have listed the part numbers below.
Motor, paper feed assembly (M101) (HP Part #: RM1-8285-000CN)
Paper Feed Roller Assembly (HP Part #: RM1-8411-000CN)
The motor would have failed the second time because the other part was too tight and hard to drive which would have resulted in an overcurrent condition.
HP Office... | Answered on Jul 23, 2020
Contact HP directly to inquire.
HP Office... | Answered on Jul 16, 2020
HP OfficeJet 6700 Premium All-in-One Wireless Office Machine Logo
2 questions posted
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
View Most Popular
  • HP Office Equipment & Supplies
Most Popular Question
up date hp officejet 6700 primium all in
  • Office Equipment & Supplies
