New blank ink not accepted, error code 5200 occurs
SOURCE: Canon mx700 rejecting remanufactured ink cartridges
big issue with remanufacturing is how integritous is the fit of the cartridge, and also the interface. When these are re cut, so to speak, tolerances can stack up, and one thing about Canon, is they are a stickler for tolerances. You may have an issue with the cartridge fitting in the carriage, but not interfacing with the system. Happens sometimes..
got backup?
SOURCE: Error 5200
Error 5200 is a printhead temperature error, sounds like you need a new printhead. The part number is printed on the side of the printhead. it's a QY6 number
SOURCE: canon printer mp270 with error code 5200 ( ink
Often it can be caused by dirty contacts on the print head, so clean them with contact cleaner or methylated spirits this may just fix your problem, try that before you do anything else If not that, then it may be Over heating or Under heating of the print head assembly, according to manufacturer.... replace head assembly...
SOURCE: Canon Printer MX328 displaying message "Printer
Please reset the printer
1. Turn off your printer
2. Press and hold the
STOP/RESET button
3. Press and hold Power ON button
4. While
holding the Power ON button, release the STOP/RESET button
5. While
holding still the Power ON button, press twice the STOP/RESET button
6.
Release the Power ON button
7. Wait until it display an "idle"
message. It will take about a minute.
8. When "idle" appear, open
the top cover to expose the cartridges.
9. Lift up the cover for
cartridge holder and take out both the black and color cartridges
10.
Return the cover of cartridge holder and turn off the printer
11.
Return the top cover and turn on the printer again
12. After the
printer initialize, return the cartridges.
1. Press and Hold the
STOP/RESET button and wait until it self restart.
2. Release the
STOP/RESET button the the printer is restarting.
3. Wait for a few
seconds
SOURCE: how to fix error code 5200 on canon printer MP258?
Here's the procedure. This code is normally encountered after refilling an ink cartridge and replacing the cartridge. Turn off printer. Hold down Stop/Reset button with one hand and turn printer on with other hand. After green light comes on for the ON button, press the Stop/Reset button two times and you should see the green light blink off and the orange alarm light blink "on" with the first press and then the green light comes back on for the power button and the orange light goes off with the second press (if you did it correctly). Now, you need to hold down the ON button about five seconds, then let go to shut OFF the printer. When you turn it back on, the printer should be back to the factory original condition. Make sure you set all your printer properties the way you want them again from your printer properties dialog boxes because some of the settings may have been stored in the printer's EEPROM, which you just reset to get rid of the offending alarm code.
