It may be that the exhaust duct is blocked or the filter is dirty.
That can cause the oven to run chronically hot, which damages the microwave.
The whole duct needs to be checked for any blockage.
You will need to remove the oven from the wall.
To remove it from the
wall, the
installation instructions are very handy, and it's best to have
two people since the microwave can be heavy and awkward.
Whirlpool customer
service is here and you can also enter your
model number on that page to download your owner's manual, installation
instructions, etc..
You can find links to helpful exploded view diagrams and order parts
here.
I'd recommend that your bookmark this link to your favorites.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
You first want to be sure your hood vent exhaust fan is working properly, that your grease filters are not clogged, that your charcoal filter (if equipped) is being changed every 6 months or whatever the owner's manual recommends, and that your exhaust duct work and outlet are not blocked.
You can also download the installation instructions from the link above and they will help you in checking the ducts and outlet.
If they're all okay, to prevent future moisture buildup, I recommend wiping the condensation off the walls and inner door surfaces after cooking, and leaving the door open a while to help it dry out further.
Plus I always recommend that you use the hood exhaust vent fan whenever you're cooking on the stove top to keep heat, steam, and
grease out of the controls and the door panels.
Once troubleshooting and prevention are covered, then you can clean and repair the inner door surfaces.
You have to separate the door panels (as shown in the attached photo)
and then you'll see the previously hidden screw(s) you need to remove.
Or you can watch a YouTube video (not a video I
made) that demonstrates how it's done.
You can also find
helpful exploded view diagrams and order parts by entering your full
model number here.
If the rust is bad, the area will first have to be sanded smooth and
cleaned and dried thoroughly.
Then you can apply some
high-temperature appliance paint, available from places like Wal-Mart,
Lowe's or Builder's Square.
If the wire mesh screen is damaged beyond just surface rust, it will have to be replaced, as it prevents microwave leakage, which can result in arcing or a fire.
We're
Two problems found. The electrician that installed the micro. installed it incorrectly. The fan was supposed to be turned so that the exhaust would go through the pre-installed duct in the wall. To remove the grill, there is two screws on top of the micro. which have to be removed. The builder put in a deeper cabinet that covers the screws because it looks better. To fix it I have to drop the micro, take off the grill, clean it and all the grease off the micro., replace the charcoal filter, turn the fan so it will exhaust through the duct and reinstall the micro.
The exhaust motor was not installed properly - it has to be turned 90 degrees so that the blower openings face up instead of the front. Whoever installed it didn't read the directions:) Unfortunately, the unit will have to be taken down from the wall to correct the motor.
Yes, the mouse was probably attracted to the warmth and food odors in the duct work and may have gotten trapped in the vanes of the fan and died. I'd act fast...
The best bet is to remove the oven from the wall, or almost from the wall, so you can see the area of the hood vent exhaust fan.
This is safer with two people and the installation instructions will be of great help.
You can download GE
owner's manuals and installation instructions here.
We're
thoughtful rating of our answer.
You can remove the exhaust turbine unit with one screw and reinstall microwave and buy a braun external exhaust unit that fits over the hole where it is at the roof or wall and all of the noise will be outside and it will actually work. It is weather proof and will **** steam or fumes out like the best vacuum cleaner.
