20 Most Recent Maytag MMV5207AAS Microwave Oven Questions & Answers
2answers
My microwave is making a cracking sound like if it
A contaminated wave guide cover will crackle and spark.
They should be periodically checked, cleaned or replaced.
Contact Maytag for replacement parts.
Hope this fixes your noise.
1/3/2019 4:11:12 PM • Maytag... • Answered on Jan 03, 2019
Where can i get a turntable for microwave
GO PLEASE to www. repairclinic.com get it and fix it. God bless you
11/23/2013 11:41:30 AM • Maytag... • Answered on Nov 23, 2013
Fan will not shut off
I think the problem is with the switch. If it is closed (i.e. turned On), it will not go off. Try opening the switch box of the fan unit and check to ensure there is nothing in the box that may be interfering with the switch by keeping it closed (completing the circuit). Otherwise, seek the services of a qualifed electrician.MR - PNG
5/25/2012 1:44:28 AM • Maytag... • Answered on May 25, 2012
2answers
Microwave not heating food
The problem you are having with your microwave is a common one. Not heating is a problem that can be caused by three things. I'll list the most common solution first, the magnetron that actually does the heating is what is making that noise and has gone bad. It is possible for you to also have a bad high voltage diode that has opened up, solution two, or solution three is the high voltage capacitor is not working properly as well. From my experience with microwaves I am positive that it is your magnetron that is bad. If you are not do it yourselfer you'll need to take it to a repair shop to replace. However, if you know how to use a screwdriver and can unplug a couple of wires with spade terminals on them, then you can take it off yourself, find another one and replace it the same way you took it off. The magnetron sits behind the control panel of your microwave but on top. It has cooling fins on it and has 2 terminals maybe three depending and make and model that plug into it. It has 4 screws that are easy to get to that actually holds it in place. If you do not have a good local source like an electronic parts supply place then you can find the right magnetron at www.mwoparts.com. Be sure you always unplug the microwave before touching or trying to take the he cover off and then when you take the magnetron off also.Good luck and God bless.
10/21/2011 7:55:22 PM • Maytag... • Answered on Oct 21, 2011
2answers
I put some food in to heat up and it is staying
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
hjkg
9/14/2011 12:03:15 PM • Maytag... • Answered on Sep 14, 2011
I heard a pop and now the micro is not heating but...
Basic Microwave Oven TroubleshootingTips
heatman101.,/,/
3/27/2011 6:13:24 PM • Maytag... • Answered on Mar 27, 2011
Hello, I had used my microwave
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
2/25/2011 3:39:20 PM • Maytag... • Answered on Feb 25, 2011
Microwave seem to be working but not heating
Basic
heatman101
2/22/2011 3:41:55 AM • Maytag... • Answered on Feb 22, 2011
Unit suddenly stopped working as if receiving no
Basic
heatman101
1/16/2011 8:22:06 PM • Maytag... • Answered on Jan 16, 2011
Our microwave does not even sound like it's trying
Could be any of the HV components...there may be a relay for turning the magnetron on and off that mayu be bad...there is a diode in the HV circuit you can check...the capacitor may be bad...or the magnetron tube may be bad...be sure to short the capacitor with an INSULATED screwdriver before you work on the HV components...not doing this can result in DEATH by electrocution..the voltage is in the order of 2000 volts at a very high joule rating.
1/8/2011 6:22:38 AM • Maytag... • Answered on Jan 08, 2011
Wicrowave runs but food not
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
12/27/2010 12:24:09 PM • Maytag... • Answered on Dec 27, 2010
Comes on when I shut door seems to be heating,
We see (and repair) this a lot. The problem is a shorted cook relay (RY7) on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid with a one-year guarantee.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
11/21/2010 7:59:51 PM • Maytag... • Answered on Nov 21, 2010
MMV5207AAS stainless_steel 1100 Watts Microwave Oven: I heard a pop and now the micro is not heating but...
heatman101
gdhj
9/30/2010 10:00:53 PM • Maytag... • Answered on Sep 30, 2010
My microwave is not heating food?
heatman101
dghj
9/30/2010 9:59:31 PM • Maytag... • Answered on Sep 30, 2010
heatman101
fsghgs
9/30/2010 2:35:49 PM • Maytag... • Answered on Sep 30, 2010
The microwave had been working fine we now have no power at all
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
8/7/2010 5:51:58 PM • Maytag... • Answered on Aug 07, 2010
Maytag MMV4184AAW Microwave not heating
If you are looking to repair this yourself (along with assoceated risks) to cut test time in half the first test point would be to check for both live and neutral feed to the high voltage transformer. If you have both live and neutral here then the control circuit is working and the fault will lie within the high voltage circuit.
Hope this helps
1/7/2010 3:52:53 PM • Maytag... • Answered on Jan 07, 2010
Maytag MMV5207AAS Microwave Oven Logo
42 questions posted
Top Maytag Microwave Ovens Experts
Marvin
Marvin
Paul Bade
Steve
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Microwave Ovens
Most Popular Question
microwave not heating food
  • Microwave Ovens
