20 Most Recent Whirlpool MH2175XS Microwave Oven Questions & Answers
Hello Keith Sprague, Spelling is close and your guess is quite excellent... Before you ENGAGE in a wholesale repair effort... You should check your machine is not in DEMO mode... Demo Mode Activate to practice using the control without actually turning on the magnetron. Touch and hold number pad "3" for 3 seconds. The "DEMO" icon will appear in the display. Repeat to exit Demo Mode From page 3 (of your operators manual) Whirlpool MH2175XSB User Instructions Electrical Requirements Hope this helps Carnac the Magnificent
Whirlpool... • Answered on Jul 02, 2017
may be magnetron or high voltage circuit problem
Whirlpool... • Answered on May 19, 2014
may be short circuit at high voltage section replace diode or magnetron
Whirlpool... • Answered on Jan 28, 2014
Check on the material the containers are made of. If they are not microwave friendly then they will cause problems.
Some materials are designed to "Roast" the contents by absorbing the energy.
Check with a Pyrex glass container and water. The glass should stay fairly cool.
Whirlpool... • Answered on Nov 18, 2012
No! the fuse is fine, there are three likely causes, magnetron, "heats food" cracked high voltave diode, or a shorted high voltage capacitor.
Whirlpool... • Answered on Mar 28, 2012
This can be a sticker that glues to the panel and it is possible that the touch pad glue had come off.You need to refix this to the panel if this seems to come off.
Whirlpool... • Answered on Oct 25, 2011
It may be that the exhaust duct is blocked or the filter is dirty.That can cause the oven to run chronically hot, which damages the microwave.The whole duct needs to be checked for any blockage.You will need to remove the oven from the wall.To remove it from the wall, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward. Whirlpool customer service is here and you can also enter your model number on that page to download your owner's manual, installation instructions, etc.. You can find links to helpful exploded view diagrams and order parts here. I'd recommend that your bookmark this link to your favorites.We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Whirlpool... • Answered on Oct 18, 2011
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 //,.';
Whirlpool... • Answered on Aug 13, 2011
HI..there is a heating filament of an oven MAGNETRON..it s responsible of producing heat to the oven..possibly this is defective ..this filament must be replaced by a new one..theres no problem with the motor cos it runs the table power and light button seems working..HOPE THIS HELPS..thank yuo for choosing fixya..
Whirlpool... • Answered on Jul 10, 2011
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
YOUR SAFETY IS PARAMOUNT
This is a job for a professional but if you are safety clued up, here's instruction.
Make sure the !!!!any capacitors are discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 or moving coil meter on high resistance range for short circuit, (DVM's won't show the fault!), the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Whirlpool... • Answered on Feb 27, 2011
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Whirlpool... • Answered on Feb 25, 2011
If the microwave is making a humming sound, the diode s bad and needs to be changed. If the microwave sounds normal, the magnetron is bad and needs to be replaced.
Whirlpool... • Answered on Feb 08, 2011
the most common cause is a faulty magnetron.How ever you can check the thermal cuts to the magnetron if hey have no continuity then it needs to be replace. if you are not comfortable with the electricals then set it up for service most units the magnetron will be covered under a warranty.
Whirlpool... • Answered on Feb 01, 2011
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
Whirlpool... • Answered on Jan 06, 2011
Whirlpool MH2175XS Microwave Oven Logo
42 questions posted
Top Whirlpool Microwave Ovens Experts
Michael Thomas
Michael Thomas
Gerry Harvey
Gerry Harvey
Sheldon Dedek
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Whirlpool Microwave Ovens
Most Popular Question
over stove model wmh1162xvs2 stainless
  • Microwave Ovens
