Whirlpool 30-inch Electric Ceramic Glass Cooktop with Schott Ceran Surface Logo
A
Anonymous Posted on Aug 07, 2014
Whirlpool induction cooktop flashing F47 how do I fix it
The two right cook areas are flashing F47
What does error code L means on the delonghi cooktop
The L indicates that the child lock feature has been enabled. This ensures that the burners do not function while you clean the cook top and that a child can't turn on any burners.
The procedure depends on your cook top model. For some induction models, to toggle the child lock feature off, press the front right burner zone display and the booster function key (circle with a solid circle inside on the right of the selector zone) simultaneously. Then press the front right burner zone display again until the L disappears from the display.
See page 23 of the manual for the Delonghi DEIND804 available here: https://www.appliancesonline.com.au/public/manuals/Delonghi-DEIND804-Induction-Cooktop-User-Manual.pdf .
For an electric ceramic cooktop DTCH808, to turn off the child lock completely, press the bottom right + in a circle and the - in a circle (in the center surrounded by 4 of the + in a circle areas) simultaneously and then release the keys. Press the - in a circle again. See page 21 of the manual here: https://www.delonghi.com/Global/InstructionManuals/EN/EN-DTCH80B_im.pdf .
I hope this helps. Please add a comment with the model of your Delonghi cook top if these instructions do not apply to your cook top.
36" kitchen aid electric induction cooktop power comes on but burners don't get hot
Induction cook tops do not heat by convection... only the cook ware gets hot. Your cook ware has to be made or encapsulate ferrous materials. More simply put; if a magnet won't stick to the pot it won't work on an induction cook top.
Jun 09, 2019 • Cooktops
1helpful
Ge monogram induction cooktop error F
The induction cooktop will flash "F" when cookware has been removed from the surface; cookware is not present when the unit is turned on; or cookware is not centered on the element.
Position the cookware properly over the center of the cooking surface if the error code "F" flashes. Use only induction cookware and use a bigger pan, as the error code "F" indicates that the pan is too small for the cooking element.
Jan 09, 2019 • GE Cooktops
I have whirlpool induction cooktop and it does nothing. I have current and nothing. I was wondering if the fuse could be bad. The fuse is 30A/250 an couldn't find one so I tried 20A/50 not
You will definitely need the correct fuse. Get someone competent with a meter to test the circuits. Test the original fuse before going further to see if it is OK or not.
1helpful
2answers
Error message on my electrolux INDUCTION STOVE TOP
Hello - Typically error code E on Electrolux induction cook top indicates an error with the user interface board/control board. Contact a professional to move forward accurately and properly diagnose/repair the unit.
Error 11 Electrolux induction cooktop
You will need to consult a professional to have the following repaired:
1. Test flex cable betweenboards.2. Change right board.3. Change center board (on 36"models only).4. Change left board.
Jul 23, 2012 • Cooktops
26helpful
3answers
Whirlpool induction ceramic cooktop error E6
my induction ceramic cooktop is showing an error code E6 on two of the elements...what is the problem and how do I get it fixed
Dec 15, 2009 • Cooktops
Top Whirlpool Cooktops Experts
vince
ADMIN Andrew
ADMIN Andrew
Are you a Whirlpool Cooktop Expert? Answer questions, earn points and help others
