Question about Cooktops
36" kitchen aid electric induction cooktop power comes on but burners don't get hot
Carl Rock
  • 2,261 Answers
Induction cook tops do not heat by convection... only the cook ware gets hot. Your cook ware has to be made or encapsulate ferrous materials. More simply put; if a magnet won't stick to the pot it won't work on an induction cook top.
Posted on Jun 09, 2019
5 Related Answers
Benimur
Louie Role
  • 6966 Answers
SOURCE: Whirlpool electric Cooktop's one burner not heating
Initially, it could either be:
  • open heating element (most likely);
  • open temperature limiter (least likely);
  • faulty/loose connection/wiring (a possibility).
Please confirm that it is a Whirlpool RCC3024 Electric Cooktop.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 11, 2008
Benimur
Louie Role
  • 6966 Answers
SOURCE: RCC3024 cooktop one burner wont heat
Hi again,
It would seem you posted anew.
For some reason I could not locate related literature for a RCC3024LD01,although there are for LB01, LQ01 and a LT01. Most of the components inthese models could be checked with the use of a continuity tester(multitester VOM/DVM). The idea is to check for continuity of eachcomponent. If we are to assume that the heating element as a likelysuspect, it is a matter of checking if the coil is continuous, that isno break anywhere in between. The test prods of the continuity testerwould be applied to the two (2) terminals of the heating element andthe tester should deflect/display how much is the resistance. Normalreading shouold be pretty low while no deflection/reading indicates anopen coil and therefore would require replacement.
These additional documents may be of help to you:
  1. exploded parts diagram;
  2. parts list.
Cheers.
Anonymous
SOURCE: Wolf electric induction stovetop
We had the same problem with the Wolf induction stovetop. They came out and changed out a part and have never had that problem again. They said there was a problem on all units that came out earlier this year (2008) so if you are one of those, you should call them and have them change that out. But... I am also very frustrated about the inability to fry things on this unit. I don't fry very oftehn but it gives very unsatisfactory results, constantly shutting the heat off and then back on. Hmmm yumm.... soggy rare ahi- uncrispy chicken- anybody?? HELP!
Posted on Nov 25, 2008
daddy1264
Duane Grant
  • 76 Answers
SOURCE: burner on electric ceramic/glass cooktop is getting too hot
sounds like you need a new thermostat
Posted on Jan 08, 2009
Roipatrick
  • 906 Answers
SOURCE: induction cook tops
good day,
hope this link below will solve your problem.
kitchen appliances
Posted on Jul 31, 2010
I am having error codes 35 and 75 come up on my induction cooktop
Thank you for your post, friend!
I located that on Electrolux Cooktop error codes "35" and "75" stand for input voltage too low. It could be an issue with your filter board or an issue within the voltages. I would recommend having a professional come out to your cooktop to properly diagnose to avoid any unnecessary part purchases. -Matt
Sep 20, 2014 | Frigidaire 36-Inch Smooth Surface...
I was boiling water for potatoes on the Electrolux induction cooktop last night. Only using one of the five burners when I heard a "pop" sound and possibly a flash of light. Error code we have is EO
Hi Gail, I am happy to assist you!
It appears the main control has detected a faulty or error condition. "E0" should be followed by two more digits to indicate which error has occurred. Let's try turning electrical power supply off. It is necessary to wait roughly ten minutes to reset cook-top main controls. If resetting the power does not correct the issue or provides a new error code, at this point, I would recommend having a service technician to diagnose the problem before investing in unnecessary parts.
Dec 20, 2013 | Electrolux 36" Electric Hybrid Induction...
Replacement Griddle for Kitchen aid KGCP463KSS
If Kitchen Aid is of no help, try an appliance parts supplier
Apr 21, 2013 | KitchenAid 36 in. Architect KGCP463KSS Gas...
My electrolux iduction cook top sends error across the whole bord when I put anythng on the inductoin burner
You may try and reset the induction cook top by disconnecting the power to the unit for up to 30 seconds. This will clear most false error codes. You can disconnect power by flipping the circuit breaker off and back on. If the error code does not clear, then the unit more than likely can be experiencing an issue with the EOC and user interface board. This is not a typical do it yourself job; please consult a professional or your manufacturer.
Sep 11, 2012 | Electrolux 36" Electric Hybrid Induction...
What are the cutout demensions for a Kenmore electric cooktop model #42729?
their is a number in front of 42729 is it 110,106.564,363,or 991 ect
that is the source code and tells me if it was manufactured for sears by whilrpool,ge,frididaire,kitchen aid, ect ect ect
Jul 25, 2011 | Kenmore 36 in.42741 / 42742 / 42744 /...
Viking professional induction cooktop large burners defective
Throw your circuit breaker that leads to this unit for a few seconds, then reset the breaker This unit is very sensitive to power fluctuations.
Mar 07, 2009 | Viking 37 in. VECU165 Electric Cooktop
Cooktops Logo
114 people viewed this question
Top Cooktops Experts
Marvin
Marvin
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
