My whirlpool induction ceramic cooktop is showing an error code E6 on two of the elements...what is the problem and how do I get it fixed
My induction ceramic cooktop is showing an error code E6 on two of the elements...what is the problem and how do I get it fixed
Posted on Dec 21, 2010
E6 - Internal Electronic Temperature is higher than normal for 3 seconds
Contact technical support.Source: http://techmindviews.blogspot.com/2011/10/induction-cooker-not-working-error-code.html
Posted on Dec 03, 2011
I had the same problem on my electrolux induction cooktop
pulled it apart has three circuitboards one where the power goes in
has capasitors looks like little cans if they are misshaped or leaking
bouhgt two new ones from jcar took the board to them to confirm
4 dollars solderd them on myself make sure you have negative
posative right presto everything fine
Posted on Oct 07, 2015
Same remedy for my Omega with error E6.
Oct 01, 2018 | Cooktops
Sep 16, 2018 | Cooktops
May 11, 2016 | Cooktops
Dec 22, 2015 | Kuppersbusch Glass ceramic induction hob...
Jul 25, 2015 | Sunpentown Mr. Induction Cooktop - White
Good Afternoon friend, I appreciate your inquiry!
Typically on an Electrolux induction cooktop the "E4" error code stands for key sensor for timer. Which means you could be experiencing an issue with the right board, center board, or left board. I would perform a reset on your cooktop and you can do that by flipping the household circuit breaker off for ten minutes.
If that does not assist with clearing any false error codes or the error "E4" continues to display I would suggest seeking assistance from a professional for proper diagnosis and repair. Hopefully this helps. -Matt
Oct 18, 2014 | Electrolux 36" Electric Hybrid Induction...
Apr 16, 2014 | Kuppersbusch Glass ceramic induction hob...
Hello it07002 - You may try and reset the induction cook top by disconnecting the power to the unit for up to 30 seconds by flipping the circuit breaker off and back on. This often clears most false error codes. If the error code does not clear, then the unit more than likely may be experiencing an issue with the EOC (Electronic Oven Control) and/or user interface board. This is not a typical do it yourself job; please consult a professional or your manufacturer.
May 07, 2013 | Electrolux 36" Electric Hybrid Induction...
Jul 15, 2012 | Whirlpool 30-inch Electric Ceramic Glass...
Aug 21, 2011 | AEG 23 in. 6410KF-N Electric Cooktop
8,671 people viewed this question
Error message is F47
My induction cooktop shows E6 error after running for hardly 5 mins. What might be thereason behind this and kindly provide me the solution too.
