8 years is pretty good for a rechargeable battery, I would say yes the battery needs to be replaced, although it may be cheaper to purchase a new shaver ?
In the event that the scale battery needs to be replaced, (display shows "Lo"),
open the battery cover on the bottom of the scale and replace the old battery with
a new 3V lithium battery.
If it is from the groups then the jet filter on the top of the group needs to be cleaned, replaced and or jet needs to be cleared of minerals. Before removing 17mm nut make sure you have new o-rings to replace the old ones.
the answer to your question is [yes]or the gas in the system is expelled and needs replaced if this machine is 10 years old take my advice and replace the refrigerator as it will cost more to replace plus an engineeers costs.[buy a new one].adrian
> tech guy said that the main-board needs to be replace.
> Is there any way to repair the same one?
Yes, but it will probably cost more than to buy another camera.
You probably can remove the disk-drive, and connect it to your computer, to "rescue" any movies currently on the camera.
Or, if you purchase an identical camera, you can temporarily "transplant" the old disk-drive from the old camera into the new camera, and then upload any movies to your computer. Then, re-insert the new disk-drive into the new camera.
If you replaced the drum with a new one, then a special plastic piece with slots in it will be ejected. This will reset the "Replace Drum" message. Now the light print is probably due to the toner needing replacing. When you put in a new drum, it needs new toner too. Unfortunately, most people replace the toner into the old drum, which does no good and becomes wasted. NEW DRUM NEW TONER. Now if you have replaced the old drum with another old drum, you won't get the reset done properly and the new drum won't load any toner either. Perhaps you accidentally removed the plastic sheet when you replaced the drum? Well then, find the piece and run it through the paper feed, it will then reset. Best of luck
yes exactly.the heater also needs to be replaced.but in very rare chances the heater is checked ok.so heater needs to be replaced but before going for new heater get the old one checked by meter.and check if its showing proper voltage on its terminal.
for getting required parts you can get it from
www.repairclinic.com
This will help. Thanks please keep
updated.please do rate the solution positively .thank you for using fixya
I contacted customer support... they tell me the FAQ information on their own website is incorrect. The opposite is true, therefore the following is correct:
If it does not beep, the powerboard needs to be replaced
If the unit continues to beep, the keypad needs to be replaced
Here in Canada, they will send you a new one within 3-5 days free of charge. Call customer support:
Canada: 800-501-9471
US: 800-677-LOCK
The woman was very friendly. Great customer support!
