G.E. Arctica Profile Frig produces bad drinking water
The bleach idea sounds the best. How did you get the bleach into the system? It would have to be under pressure from the water inlet to the connection on the refrig, running the water dispenser for several minutes until you could smell the bleach from the dispensed water, plus the icemaker would need to be cycled, and then left for at least 15 minutes to an hour, then flushed with clear water. (again, several, as in about 10, minutes for this step) (icemaker line also needs to be flushed with clear water) Best to be done with the filter bypass plug in place, then when done, a new filter. It is not really possible to replace all the water lines, as the one inside the freezer door cannot be replaced without replacing the entire door.
