Sharp AR-M455N Copier Logo
Question about Sharp AR-M455N Copier
What to do ce-02 netzwerkfehler sharp ar-m 207
Skelton Business Equipment
    Guru:
  • Sharp Expert
  • 106 Answers
If you can translate this page, here is the solution:
Sharp Scanner CE 02 Cannot Connect to Server Consult your Network...
Posted on Aug 06, 2014
5 Related Answers
Anonymous
  • 148 Answers
SOURCE: F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
Posted on May 26, 2008
Anonymous
  • 135 Answers
SOURCE: Network Error code CE-02
the ce-02 code is just a communication error it general in nature so you could have a couple different issues going on
Posted on Apr 19, 2009
Anonymous
  • 22 Answers
SOURCE: SHARP AR 5020 error F5-02
you reset your eror code program c#0#
Posted on May 30, 2009
unkl foddy
  • 120 Answers
SOURCE: sharp arm 450n (ce-02)
1) If you're actually scanning to an email address, make sure your SMTP email server information in the copier's web page is correct.
If you are using names instead of IP addresses, also make sure your DNS server IP's are correct.
2) If you're scanning to create the fake email set up by Sharp Network Scanner tool, the connection info in your copier is old and needs to be refreshed.
From the computer you're trying to scan to, right click on the Network Scanner Tool icon in the tray, go to Automatic Profile Update, and select Update Now. If you have no tray icon, reboot your computer.
If your copier is set up to store names instead of IP addresses, make sure your DNS information is correct in the web page.
Posted on Jul 09, 2009
Anonymous
  • 118 Answers
SOURCE: CODE L4-02 JUST ILUMINATE ON MY SHARP AR-M 350U PHOTOCOPIER
That code means you have a drum drive motor failure. The drum is the long, cylindrical green-blue tube you'll see when you open the left-side door.
Chances are some paper jammed up inside the drum process unit (that black frame that holds the drum) and it's keeping the drum from turning. Check the drum/process unit and make sure they are clear of any material that could cause a jam.
Posted on Aug 28, 2009
I have a Sharp AR-M550N; It's giving me a code Network error CE -02? How can i solve that error?
CE 02 is rarely a machine problem, It normally is an addressing problem between the machine and the network. That code indicates a communication problem, normally relating to scanning.
Often times it is a wrong character in an address.
AR-M455N Error Code CE 02 thank you
how change serial number logical in sharp arm455
1helpful
What is Network error (CE 02) thank you
Network Error CE-02 - this is where the machine cannot communicate with the SMTP Gateway / Mail Server for scanning. Check that you have a connection with the network and that you have the correct SMTP I.P address.
If you are using a host name for the mail server make sure that you have configured the DNS entries correctly.
Hope this helps.
Our machine is a Sharp AR-M55OU and it is giving us the error CE-02 when we try to scan. What does that mean?
I believe the CE-02 is a generic network error.I had the same issue, with us it was a DNS issue. We had old computer accounts in DNS confusing the scanner when using hostname. Have your network admin scrub DNS and see if it solves it.
Sharp AR-BC260 shows the network error CE-02
You need the Sharpdesk Software CD and you will have to install it in order for the scanning function to work.
Getting a CE-02 error when trying to scan.
1) Check that the Network Cable is
inserted properly.
2) Check that the connected network
supports TCP/IP protocol.
3) Check from the Web Page that the
Primary/Secondary E-mail Server
Address or the Destination FTP server/
Desktop PC address are properly set.
4) If the above address is described with
Hostname, check that the DNS server
is properly set.
5) Check that the SMTP server/FTP
server/NST causes a trouble or not.
2helpful
3answers
Error code CE-02 when in the scan mode.
the FTP server cannot be found. This is a network error. If it is connected to a network, check with your IT person to set up the FTP server.
We have sharp AR 206 F502 code is coming what is this code and how solved the metter i change the lens unit,optical unit,expouser lamp,cable but stil the code please help me what i do thanks
F5-02 - Exposure lamp blown
**ALWAYS DISCONNECT POWER BEFOE WORKING ON MACHINE****
Check the exposure lamp, if defective replace.
Check inline exposure lamp fuse, if defective replace.
Also check flat cable from CCD to MCU PWB , if cut or defective replace.
Last -- brds (boards)
2answers
Network Error on display
Have you setup your smtp address on the machine? From any workstation in the same network open your web browser. Key in the IP address of the mfp copier. Goes to network setup and key-in your smtp address.
Top Sharp Office Equipment & Supplies Experts
George Mclaughlin
Norman  J Weimar Jr
Norman J Weimar Jr
Cosmas Matanda
Cosmas Matanda
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
