20 Most Recent Sharp AR-BC260 Color Copier Questions & Answers
good day, my Sharp AR 5731 showing the message Call for Service . Code : H4-00 can you help me to fixed my problem. thanks and God Bless
Sharp AR-BC260... | Answered on Jan 29, 2020
Heat roller abnormally low temperature
Check blinking of the heater lamp
with SIM 5-2.
When the lamp blinks normally:
Check the thermistor and the
harness.
Check the MCU PWB thermistor
input circuit.
When the lamp does not light:
Check for heater lamp
disconnection or thermostat
disconnection.
Check the interlock switch.
Check the power supply PWB
and MCU PWB lamp control
circuit.
Clear the trouble with SIM 14.
Sharp AR-BC260... | Answered on Apr 21, 2016
Replace the fuser
Sharp AR-BC260... | Answered on May 11, 2015
Type in "p" "*" "C" " *" (that is p button, star button, p button, star button.) the machine will go into sim mode enter 14 then press execute which appears on the lcd and the yes to confirm, then press CA and the machine should turn off then back on again
Sharp AR-BC260... | Answered on Oct 16, 2014
clear code for code H2-01
Sharp AR-BC260... | Answered on Aug 21, 2014
Hello :
Software for your copier can be found on the manufacturer website .
I hope that will help .
Sharp AR-BC260... | Answered on Jul 15, 2014
H5-01 means repeated paper jams on the Sharp photocopiers. Once the paper jam is cleared properly, you need to clear the error condition. Put it in 'Copy' mode. Press on the keypad: Related Groups. Printers, Copiers, Scanners &
Fuser unit problem.
Sharp AR-BC260... | Answered on Jan 08, 2014
Do the black lines only show up when useing the adf???? Or do they show up on both the adf and the copyboard glass??? If it is only when using the adf...... The fix is easy.... you have to clean the smaller piece of glass that is to the left of the copyboard glass with windex or rubbing alchola. If it is with both you may need a new drum and blade or a new ufr... Good Luck
Sharp AR-BC260... | Answered on Aug 02, 2013
it is a fuser malfunction!
Sharp AR-BC260... | Answered on Jul 08, 2013
Without the sub code hard to say, but check the thermistor in the fusing section. F2 also refers to toner empty and some other issues.
Try to get the sub code it will helps. In case you need the service manual you can get it from http://fixmfp.com
Sharp AR-BC260... | Answered on Jun 22, 2013
H4-00 relates to the fusing unit not reaching the desired temperature. This could be due to a heat lamp or thermistor failure. I would recommend calling your local service engineer. hope this helps.
Sharp AR-BC260... | Answered on May 09, 2013
http://olsonbros.com/sharp/support/pdf_trbl/trbl-arbc260.pdf
Sharp AR-BC260... | Answered on Jan 30, 2013
F2 00 Content Toner control sensor open/sensor
trouble
Detail Toner control sensor output open
Cause Connector harness trouble
Connector disconnection
Sensor trouble
Check and
remedy
Check connection of the toner control
sensor.
Check connection of connector and
harness to the main PWB.
Check for disconnection of harness.
Replace the sensor.
This is right from the service manual...one thing you can try.
1)copier must be up to ready state.
2)press #,*,clear,*(that will enter you into a simulation mode)
3)press 14, execute,yes.
4)or 14, print button.
5)press CA (clear all) button.
that should reset it to a working state without causing any damage to the copier.
Sharp AR-BC260... | Answered on Aug 10, 2012
Model AR-M257 - I have several Sharp MFP devices at different locations and all are set up to scan through our email server using a special account I have just for this purpose. I have all of them setup using the external IP address of our Exchange server (not its name or FQDN) and I have firewall rules setup to allow SMTP from the WAN IP addresses of our different offices to the LAN IP address of the Exchange server. It worked at all the others but this one. I was getting the following error when trying to send a status message (under Log) from the device to my email account as a test: [error 973] incorrect format for primary smtp server. And when I tried to scan through our email server I would get "network error". However, a connection test succeeded. I had everything set correctly for SMTP and DNS but as I was trying anything I could to get it working I went to mDNS under Services and it was enabled. I disabled it and then I could get a status message to be sent to me and we could send a scan through our email server.
Sharp AR-BC260... | Answered on Aug 07, 2012
Sharp AR-BC260 Color Copier Logo
85 questions posted
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Office Equipment & Supplies
Most Popular Question
fix sharp copier ar 5731 error code
  • Office Equipment & Supplies
