Microwave Ovens Logo
A
Anonymous Posted on Dec 13, 2017
Convection oven fan not working. Everything else works but fan will not come on in convection mode. I turn it on, wait for it to preheat, and wait the 5 minutes it's supposed to take, but the fan does not come on. The fan blades will turn easily with a finger, but not from the stove controls.
Paul Woodward
Level 2:
Sergeant:
  • Expert 200 Answers
  • Posted on Dec 21, 2017
Paul Woodward
Expert
Level 2:
Sergeant:
Answers
200
Questions
15
Helped
56517
Points
923
Open it disconnect fan and put a 9v battery across leads if it works it a mainboard ploblem. if it doersnt probs need to nuy a new fan. its a standard test u can do on most fans in laptops etc..
5 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Jan 03, 2009
SOURCE: GE Microwave/Convection JVM 1090 oven won't reach temperature
You probably have a bad thermistor.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
(At that site, that part is misspelled as "thermister" for your model).
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Accessing some components for testing will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Phil Sciacca
  • 36 Answers
  • Posted on Jan 08, 2009
SOURCE: Sharp 1870 just quit cooking and no turntable
The fact that the microwave and convection both do not heat indicated that the oven is in demo mode, check the user manual, otherwise it will possibly be a relay not triggering, may need a pcb replacement, check Demo mode 1st....Phil
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Feb 23, 2009
SOURCE: sharp r96st stops at 1 sec and halts whilst preheating oven
This is a problem in one of the damper-related components, either the switch or motor or the damper door may be binding.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp models stop after 59 seconds.
See the attached sample photo for a typical damper assembly.
Info on ordering Sharp UK parts / spares is here.
Anonymous
  • 574 Answers
  • Posted on Aug 24, 2009
SOURCE: Exhaust fan not working, humming noise upon switching
fan motor locked up
A Miller
  • 8404 Answers
  • Posted on Sep 09, 2009
SOURCE: microwave sparked out now it does not work
You had something metal inside the microwave. Do you have a rack inside on a revolving tray? On my microwave, if the foot of the wire rack is not on the revolving tray, it will spark against the floor of the oven. Microwave will go around round pieces of metal - it will spark if it finds a flat surface. I dont think you did any damage to your machine but try to not do this again.
I hope this helps you.
Advantum GE 120 microwave/convection oven is smoking when I try to preheat the convection part. It's 2006 model w/the house we bought in 2 mos ago. Prior owner never used that part.
When convection mode is used heater inside gets heated and as you say that the previous owner never used this mode,when ever the heater used for the first time it may produce smoke as the coating over it heats up giving smoke,no need to worry use it regularly it will work perfectly
Ho to preheat emerson MWG9115SB microwave convection oven for baki g
it is not a convection oven only microwave and there is no preheat. refer to your owners manual.
FFFF error code on convection preheating
F is for fan. Why is your fan not doing its job I ask?
2answers
No heat generated in microwave or convection oven mode
I just read that starting the microwave as usual and then slightly pressing in the handle (you can hear the heater(?) come on will make the heat come on. Tried it and it works. My repairman told me it needed a new magnetron ($700) but that was totally wrong. I will be trying another repairman to replace handle mechanism.
My Dimension4's convection oven often starts to make grinding noises when it preheats.
From the description it is the turnable motor, eventually it will need to be replaced down the road.
Sharp r96st stops at 1 sec and halts whilst preheating oven
Convection Preheat doesn't reach the Chosen Oven Temperature
I would first suspect the thermister (thermistor) or a low line voltage, weak control board relay etc.
But the service manuals will show you how to safely disassemble, test and repair the unit.
We have the service manuals for this model and have uploaded them to our site here and here to help you.
You will need the
free Acrobat Reader to view or print them in case you don't have it.
The best place to order parts for this brand is Encompass (formerly Tritronics). Or you can call them toll-free at 866-779-5835.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
[email protected]
http://www.microwavedisplay.com
1helpful
Sharp Carousel Convection Microwave R-9H56 suddenly stops heating
at highvoltage section wiring may bae problem, check wiring and connectrors of magnetron and capacitor and transformer.
Top Amana Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
