20 Most Recent Amana AMV6177 Stainless Steel 950 Watts Convection / Microwave Oven Questions & Answers
the question is can you get one???? chances are youll have to tear it completely apart
Amana Microwave... | Answered on Jan 02, 2020
HOW WOULD WE GUESS . TRY IT AND FIND OUT FOR YOURSELF . THAT IS HOW WE ALL LEARN THINGS
Amana Microwave... | Answered on Feb 23, 2019
You can try checking out the installation manual for an idea of how it was installed. It should be sitting on a mounting bracket and not attached to the sheetrock itself. However, you might be pulling on the mounting bracket when you tip it forward. You should have an extra set of hands to help you pull it straight forward and out, instead of tipping it.
The installation manual can be found at https://d1vofmza27mmhi.cloudfront.net/product-pdf/amana-amv1150vaw-installation-instructions.pdf.
Amana Microwave... | Answered on Oct 11, 2018
Place a telephone call to your local Amana servicer and report the message displayed.
Amana Microwave... | Answered on Jul 26, 2018
The LV control (mains side) fuse is on the control board.
The HV (lethal side) fuse is housed inside a plastic shell, next to the HV capacitor.
For both, the outer shell (microwave oven's cover) needs removal.
BUT:
Mains must be off, preferably about 15 minutes to allow HV capacitor to discharge through it's internal drain resistor.
AND:
There will probably be one or more security tamper-proof screws on the cover, to prevent accidental injury through electrocution.
WHY:
Microwave ovens are the most lethal household appliances to open when untrained hands poke around.
SUGGEST:
Get an experienced tech to check it out.
What makes you believe it's a fuse?
Amana Microwave... | Answered on Jul 25, 2018
If there is one it will be in the rear of the machine right by the power cable. Sometimes that are a plastic carrier that pulls out sideways or or a screw cap that reveals the fuse. For any internal fuses, you need professional servicing as the case is fitted with security screws due to the dangers of microwave emissions, ultra high voltage and a poisonous core to the magnetron.
Amana Microwave... | Answered on Jul 15, 2018
You have a serious short circuit, I suggest you call for a service technician
Amana Microwave... | Answered on May 31, 2018
Did you have a power failure? Could be an overheat situation. Try unplugging the unit, wait 30 seconds and plug it in again. This resets the unit as long as there isn't a breaker or fuse blown. If it is a power issue, the display should start flashing. Did you get any error codes?
Amana Microwave... | Answered on Mar 30, 2018
if no battery needed check gap on ignitor too close or too far wont work
call amana repair service ,
open it disconnect fan and put a 9v battery across leads if it works it a mainboard ploblem. if it doersnt probs need to nuy a new fan. its a standard test u can do on most fans in laptops etc..
Amana Microwave... | Answered on Dec 21, 2017
Probably a defective controller
Amana Microwave... | Answered on Dec 11, 2017
If it was new in 2004, it probably is trash now (13 years later)
Amana Microwave... | Answered on Sep 11, 2017
Amana AMV6177 Stainless Steel 950 Watts Convection / Microwave Oven Logo
0 questions posted
Top Amana Microwave Ovens Experts
William Miller
William Miller
Ekse
Mike
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Amana Microwave Ovens
Most Popular Question
troubleshooting microwave turntable fan
  • Microwave Ovens
