Hello, My modell is unbearable noisy while cooling the videocard, what can i do? Thanks for the answers
Hi
My laptop msi 6837D Intel Core 2 DUO CPU 2.0 GHZ, TYPE T5750
WAS PROBLEM WITH VERY NOISE FAN.
FOUR SCREW UNDER LAPTOP NEED TAKE OUT.
ON LITTLE GAP SHAPE U PUT SHORT SCREDRIVER AND TAKE OUT PLASTIC COVER, this plastic cover is having around little clips/ ears.
you WILL BE SEE FAN.
TAKE TWEEZER AND TRY CLEAN FAN.
FAN HAVING 4x very little screw- use magnetic scredriver.
Between sheetmetal and plastic insert 9cm long plastic pipe already fixed with WD 40 spray( or Astral ,...) , push him to side where is axis for fan , bottom side and spray only 0.5 s. Turn laptop back to normal position and oil will be slowly fallen down, still turning fan with finger for little while. Try again second time and will be enough oil for fan. Dont spray from air have to be long pipe touching axis with bearings.
IF is still very noisy the FAN so probably is too much worn and have to be replaced by new.
