Question about Windchaser PACR10 Portable Air Conditioner
Hi, if it trips the reset, you have a short in some part of the unit. Could be the motor, or several things that would cause this. It can be repaired if you take it in to a appliance repair shop. You know as well as I do it may be a minor problem or major, and its the labor that will get your $$$. Get a estimate and compare to a new unit. I hope I have been of some help to you.
Sincerely,
Shastalaker7
Posted on Jun 15, 2010
Testimonial: "Thank you. I'll proably buy a new one."
Mine only trips on heat. All other settings work just fine. Any help?
Posted on Sep 23, 2019
I'm having a similar problem. The other night there was a storm and we lost power for just a couple minutes. When it came back on the window air conditioning unit atarted turning on & off. I mean it will literally run for 2 to 3 seconds then turn off. It keeps doing it on and off on and off. I have tried unplugging it for a while, flipping the breaker, everything.... Please someone help me...Oh by the way the A/C is a GE.
Posted on Jun 23, 2019
SOURCE: A6414w7b b wall unit gfi plug keep tripping
GFI plugs go bad very often if you had a storm in you area. You need to replace the plug. Go to aplliance parts house and they will sell you the new cord. Feed back please.
Posted on Jun 13, 2009
Check out these three main causes of a portable/room unit's failure:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Portable_Room_Air_Conditioners_Window_Air_Condit_Not_Turn_On.htm
Brad
Posted on May 25, 2009
SOURCE: when I plug in the unit it trips the reset button every time. Its
This is only a 5,200 BTU unit - for single room use.
If you're sure the voltage ok, it sounds like the unit is new and should be under warranty.
Posted on Jul 25, 2009
SOURCE: admrial air conditioner keeps tripping it's plug
Hi, you either have a short in a componant or it may be that the outdoor coil is dirty and will need to be washed out with your garden hose. If it trips but you are able to reset it and it will run for awhile, its a good sign the condenser coil may be plugged causing high head pressure. If it trips and you try and reset it but can't, you have a dead short in a control part, motor, compressor, or what. Try washing this coil but be careful not to bend the aluminum fins as this will make it worse. Please let me know if this solves the problem or not, and if not we can go into it deeper.
Sincerely,
Shastalaker7
Posted on Jun 28, 2010
Feb 13, 2013 | Bradford White CF-50-6 50 Gallon - 119,000...
Sep 07, 2012 | Whirlpool Heating & Cooling
Aug 30, 2011 | Heating & Cooling
Aug 06, 2011 | Frigidaire FAH106N1 Wall/Window Air...
Jun 28, 2011 | Fedders AED24E7F Wall/Window Air...
Jun 01, 2011 | Sharp AF-S85FX Wall/Window Air Conditioner
Feb 06, 2011 | Asko T721 Electric Dryer
Feb 04, 2011 | Heating & Cooling
Jul 25, 2009 | Heating & Cooling
Apr 28, 2009 | Heating & Cooling
Nov 03, 2015 | Windchaser PACR10 Portable Air Conditioner
5,529 people viewed this question
