What is going on when it has lines showing up on the screen when i try to turn it back on; and when I try to take pictures with my camera it shuts it completely off position without me touching the on/off button. And how i don't have a manual, cables n etc. for it. Because my husband bought it from online.
SOURCE: lens won't go back in, camera won't turn on
i have the same problem with my olymus camera. its agravating because mine wont turn on and the lense is sticking out. my warrenty is up so im thinking about buying a new camera? im not sure because it cost more to repair.
SOURCE: Camera error #B03...oops, camera on before USB was connected
there is a software problem in ur camera if any one can reload the software then it will work properly or the main board of the camera should be changed
SOURCE: P850 shuts itself off for no reason
Try using a liquid contact cleaner. I read about this fix on another site, worked great for me.
A product called DeoxIT in the U.S. is what was suggested, I am in Canada and can't get that here so
I picked up a product from a company called NexxTech. Just a liquid contact cleaner.
Take out the battery of the camera. Put a few small drops of the contact cleaner on the power button and let it drip down into the switch. Rotate the on/off switch back and forth 5-10 times, put the battery back in and Voila! Fixed!
No more random on/off irritations, camera works just like it did before the problem arose a few weeks ago.
It worked great for me.
Good Luck!
SOURCE: Easy Share V1003 Turns on, then shuts down.
Make sure that you are installing a fresh/ full charge battery
Remove the memory card and the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
SOURCE: Kodak Z 1285 shut down while transferring pics - Won't start up.
you can look on the kodak home page if exist a new update to resolve this problem. but i am very sorry for you why this is a not good signal. its probably that the camera have a processor problem and dont read no more the cards. prove to first to change the card type. and look that the card have not a hold bloc system. this is the first prove change the card look if kodak have updates for this problem of the hompage of your specific model. and good luck
