20 Most Recent Kodak EasyShare C913 Digital Camera Questions & Answers
5answers
C913 Kodak won't turn on
check the battery where you insert on camera kodak has an error on mine <+> should be where the <-> is and<-> should be where the<+> is
9/20/2021 9:04:59 PM • Kodak EasyShare... • Answered on Sep 20, 2021
What is going on when my camera is acting up?
It is trying to tell you it needs a service or a repair
1/2/2018 5:10:52 PM • Kodak EasyShare... • Answered on Jan 02, 2018
How to get Sand out of my Camera?
You should not open it. You should take it to a professional for repair. Sand is scratchy, the more you mess with it, the more scratches.
8/11/2017 7:46:21 PM • Kodak EasyShare... • Answered on Aug 11, 2017
Black screen
CCD FAILURE !
Just Call KODAK they will do it FREE OF CHARGE ! ask them about BAD CCD !
it is a known manufac fault and all are doing it FREE !
Pls rate me WELL
5/31/2017 5:58:21 PM • Kodak EasyShare... • Answered on May 31, 2017
I have a Kodak EasyShare
Buy a car reader that hooks into a USB port, very cheap less than $5 Follow the link for a reader on eBay All in 1 USB 2 0 Multi Memory Card Reader Adapter For Micro SD TF SDHC MS...
4/8/2017 8:29:37 PM • Kodak EasyShare... • Answered on Apr 08, 2017
4answers
Kodak easy share c913 driver free download
You can download for free the software of your camera and driver., Just visit kodak.com/go/easysharesw or kodak.com/go/downloads., Gudluck!
10/4/2015 1:03:09 AM • Kodak EasyShare... • Answered on Oct 04, 2015
Camera will not turn on
It;s not batteries
9/7/2014 8:25:59 PM • Kodak EasyShare... • Answered on Sep 07, 2014
Internal memory is full
buy a memory card or delete the internal memory to make room.
5/25/2014 4:51:18 AM • Kodak EasyShare... • Answered on May 25, 2014
Having lines on my screen and shuts off automatic
There is a short in the system and your camera is failing. Time to send it to the manufacturer for repair.
4/30/2014 2:58:27 PM • Kodak EasyShare... • Answered on Apr 30, 2014
I plug my camara into my laptop but its not showing me the camara is connected or asking me to inport photos
Try NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
4/6/2014 10:00:47 PM • Kodak EasyShare... • Answered on Apr 06, 2014
0answers
How do I reset the photo/frame numbers?
I'm afraid your camera can't set the photo count to 1. At least the user manual does not show any possible hint how it could be done.
2/13/2014 8:31:45 PM • Kodak EasyShare... • Answered on Feb 13, 2014
Internal memory full
Internal memory is full after you shot only a few pictures Actualy you only have 11 Megabyte free for pictures. If you want to make more pictures, you have to insert a SD memory card. Make sure you buy a SD and not a SDHC or SDXC card, because nothing in the manual says your camera is compatible with these bigger cards. If you happen to have a SDHC card you are free to try if it works, but don't buy one unless you are sure it works.
1/20/2014 4:09:16 PM • Kodak EasyShare... • Answered on Jan 20, 2014
Pictures ar blurry
If you did not drop the camera. It won't be the lens. That said, please have a close look to the lens. Is the front element clean? you could clean it with a soft cloth that is used for glasses too. But also try to look into the lens. Sometimes, when a lens is left is a moist envirement, mold can grow between two elements. The glass you see inside is not bright anymore and gets a grayish look.When the battery is becoming old, you only can make less pictures with one charge, till it is old and stops. Before the camera could warn you the power is running low.
10/30/2013 2:56:35 PM • Kodak EasyShare... • Answered on Oct 30, 2013
Battery cover cracked
You may order a replacement in a choice of colors from http://uscamera.com/c913.htm
8/6/2013 11:15:26 PM • Kodak EasyShare... • Answered on Aug 06, 2013
It does not take pictures or videos when pressing the shutter button
may be you had placed the card wrong and inside the pin got pressed and only inner memory is getting used which gives less pic. due to less mb inner memory
4/26/2013 2:06:26 PM • Kodak EasyShare... • Answered on Apr 26, 2013
I NEED KODAK HELPLINE NO.CAUSE I NEED A PROFFESIONAL REPAIRING MAN IN ASSAM
www.kodak.com and customer support page.
1/27/2013 3:37:59 AM • Kodak EasyShare... • Answered on Jan 27, 2013
Can i upgrade my camera c913 firmware
Check www.kodak.com customer support, downloads for the firmware for your model.
1/25/2013 12:14:39 AM • Kodak EasyShare... • Answered on Jan 25, 2013
How do I change the pixel size when taking pictues
Hello, Go to camera MENU, SETUP and set the quality of the photos to a lower setting to reduce the image size.
1/24/2013 6:23:20 PM • Kodak EasyShare... • Answered on Jan 24, 2013
Kodak EasyShare C913 Digital Camera Logo
335 questions posted
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
View Most Popular
EasyShare Kodak
  • EasyShare Kodak
Most Popular Question
kodak c913 driver using windows 7
  • Cameras
