SOURCE: on a hotpoint aqualtis aqxx149pm i get error code f8 flashing
Hi.
F8 means that heater relay cannot be activated, you need to call an engineer.
Could be expensive, possibly a new control board needed
SOURCE: Hotpoint Aqualtis LCD display language
Follow this link and read where to find your model # and insert it in the box. I hope this helps. http://genet.geappliances.com/DocSearch/Dispatcher?REQUEST=SEARCHWITHURLCONNECTION
SOURCE: Hotpoint Aqualtis AQGF 149 Error F-05 what does this mean?
F-05 means service switch jammed.
Hope this helps. =)
SOURCE: trouble shooting the hotpoint aqualtis aqxxf149pi flashing f08
my hotpint aqualtis aqxxf149pi make a funny grinding noise when it spins help please?
SOURCE: my Hotpoint WML540 wont start
This sound like the main control board has blown and this is due to the motor shorting out, if you isolate the power supply and remove the control panel you will be able to remove the pcb/module and inspect it for signs of burning or split tracks if you find this is the case usually it is cheaper to replace the machine than purchase a pcb and motor.
Regards
Ian
