Question about Hotpoint Ariston AW125 Front Load Washer
Hotpoint Aqualtis AQGF 149 Error F-05 what does this mean?
Hotpoint Aqualtis AQXXF 149 PI Error F-05 what does this mean?
Posted by jphagura on
  • 1 more comment
  • shorty Aug 20, 2013
    Hi all,Same here : (F05 error ) I removed all the connections , layed the machine down on its side . clearly you can see the suction hose of the pump; it narows from roughly two inch to one inch. It will take just a minute to remove this hose and cleane it up ... I did the same with the pump outlet hose . This fixed my f05 error
  • Anonymous Mar 14, 2014
    Hotpoint aqualtis is not working
  • Anonymous Mar 23, 2014
    I have an An Hotpoint-Ariston aqgf 149 it gives me an error E-05. Can you show me what I have to do?
Connie
  • 79 Answers
F-05 means service switch jammed.
Hope this helps. =)
Posted on Oct 10, 2009
  • 1 more comment
  • arthur bruce Oct 14, 2011
    thank you
  • Daw Z Oct 22, 2012
    what should i do if i hv error F5?
  • Carmen Brenssell Jun 15, 2013
    I have the same error, what do you do to fix it?
neilmoto
  • 75 Answers
F05 error means that it's not draining check the pump filter as per instruction manual and look for poss money or lint
Posted on Nov 25, 2014
Petr Zizek
    New Friend:
Thank you, shorty! It was exactly my problem (F-05) and the reason was piece of cloth in the suction hose.
Posted on Mar 16, 2015
shorty
    New Friend:
Hi all
Posted on Aug 20, 2013
Door wont unlock
Some of these machines have a door lock that dose not unlock for a min. or two after wash is done. If so try the door now & it should open.
Jul 15, 2014 | Washing Machines
Hotpoint Aqualtis AQGF 149 Error F-05 what does mean?
Indesit (Hotpoint) 'F05' decodes as 'pump block'.
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and general guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
May 07, 2011 | Washing Machines
I have a hotpoint aqualtis and i have a fault come up code fo5
F-05 is indeed the water outlet blocked. You need to clean it out, also possibly the pump, & Hoses.
http://www.howtomendit.com/answers.php?id=157950
See above.
http://appliancejunk.com/ge/washer/31-9135.pdf
Service manual above.
Aug 06, 2010 | Hotpoint Washing Machines
Error code 07 on my Aqualtis AQXXF
Might be a bit complex but this is your problem and solution
REMEMBER TURN THE POWER OFF
F07: Heater relay stuck or element open circuit
This fault is only signalled when pressure switch is in empty position.
Check the efficiency of edge connector J3 on module.
Check wiring to heater and continuity of element (25 ohms approximately).
Check the efficiency of pressure switch connections and correct operation of pressure switch,
and the pressure chamber is not blocked with sludge.
Remove edge connector J3 and check wiring and contacts at positions 2, 3 and 4 on J3.
If all above OK replace pressure switch, module or eeprom as required.
Jun 10, 2009 | Washing Machines
On a hotpoint aqualtis aqxx149pm i get error code f8 flashing
Hi.
F8 means that heater relay cannot be activated, you need to call an engineer.
Could be expensive, possibly a new control board needed
Nov 19, 2008 | Hotpoint WMA35 Front Load Washer
Hotpoint Ariston AW125 Front Load Washer Logo
8,371 people viewed this question
Top Hotpoint Washing Machines Experts
Richard C Cohen
Richard C Cohen
gbob59
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
