Remove the front kick strip, on the LHS you will notice a yellow tag. with the power on on the machine pull down twice gently on this tab. this should unlock the door.
if you now notice the drum is full of water its more than likely your filter is blocked and this is what caused the door not to open.
Thanks tried this but as I mentioned the yellow tag has disconnected from the machine!!
Mate, I've been trying all day to get my door open. Found this wee nugget of info and it worked !!! Cheers for that !!!!
My Hotpoint BWD129 W/D combo is built into the cabinetry and there is no "kick strip" to open.
Brilliant! This worked even for a completely non technical person like me. Thanks so much for the tip.
Either the door latch mechanism has malfunctioned or door child lock system is on.
My aqualtis washing machine won't let me change the setting! Help! :/
