20 Most Recent Hotpoint Ariston AW125 Front Load Washer Questions & Answers
If the machine is dead, I would check the cable from the main boad leading to the front display on the door. Often the cableharness breaks at the hinge. (one of cables). If that is not the case, eather the main board or display board is dead.
Hotpoint Ariston... | Answered on Mar 09, 2016
F-05 means service switch jammed.
Hope this helps. =)
Hotpoint Ariston... | Answered on Mar 16, 2015
(and again!) Hi from retired Englishman in SW France,
There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Hotpoint Ariston... | Answered on Aug 01, 2011
John C
1 is usually for pre-wash, 2 for washing powder and fabric softner goes into the section with the level indicator should be small square section with removable top.
Hotpoint Ariston... | Answered on Feb 28, 2011
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Hotpoint Ariston... | Answered on Feb 26, 2011
This sounds very much like the belt is slipping. Belts are not expensive- sorry I do not know how much yours would cost- and are easy to be changed by a competent person.
REMOVE POWER FROM THE MACHINE AND REMOVE THE BACK.
The motor support bolts should be loosened and the old belt removed. Often putting the new belt on is a bit of a struggle, even with the motor 'loose', because it is new and smaller!
Once on it should be tensioned by pulling the motor against the belt firmly- but not over tight- and the motor support bolts tightened.
ON NO ACCOUNT SHOULD ANY FORM OF LEVERAGE BE USED TO TENSION THE BELT. THAT COULD LEAD TO DAMAGE TO THE BELT, MOTOR AND BEARINGS- EXPENSIVE!
If it turns out to be the motor, it is false economy to just have the brushes changed. Experience of others is that the brushes may only last months unless, that is, the motor is totally refurbished.
Now- to drain the water out you could follow the relevant parts of my (generic/standard) notes-
If you are unsure where the filter is, it is normally behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
Hope this is your problem solved.
Good luck,
John C
Hotpoint Ariston... | Answered on Feb 16, 2011
if your washer wont go into a spin mode it will probably the carban brushes that need replaceing in the motor
Hotpoint Ariston... | Answered on Jan 03, 2011
Hotpoint Ariston AW125 Front Load Washer Logo
45 questions posted
Top Hotpoint Washing Machines Experts
Richard C Cohen
Richard C Cohen
gbob59
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Hotpoint Washing Machines
Most Popular Question
hotpoint aqualtis aqgf 149 error f 05
  • Washing Machines
