20 Most Recent Hotpoint WMA35 Front Load Washer Questions & Answers
Why is the wash programme not working & flashing red
check door inter lock
3/2/2015 8:17:06 PM • Hotpoint WMA35... • Answered on Mar 02, 2015
Door locked light flashes which prevents it from working
hi if your interlock is playing up this will cause this try giving a bit of push on door were catch is dont slam door if light stops flashing doors locked its good idear change interlock to do this take band from round door rubber pull rubber of rim take two screws out interlock you can get it through the gap unplug put new on should be ok then but try a push on door 1st when doing lock unplug machine hope tis helps
2/17/2014 12:30:08 AM • Hotpoint WMA35... • Answered on Feb 17, 2014
Smoke coming from inside drum after spin cycle
The noise would possibly indicate that your drum bearings are on their way out, this would more than likely mean a new spider assembly, tripod in shape and houses the bearings through the drum, as well. They come in kits or bearing assembly alone for various prices, usually around 40 pounds for the kit but it would be a very difficult job if you are not familiar with this type of work, bearing extractor kits are best used but more cost, drum seals may also be needed.
1/25/2014 12:35:48 PM • Hotpoint WMA35... • Answered on Jan 25, 2014
2answers
On a hotpoint aqualtis aqxx149pm i get error code f8 flashing
Hi.
F8 means that heater relay cannot be activated, you need to call an engineer.
Could be expensive, possibly a new control board needed
1/22/2014 11:41:14 PM • Hotpoint WMA35... • Answered on Jan 22, 2014
Washer emitting burning smell and smoke on fast spin
Yes, the heating element is coming on when it shouldn't. A likely cause is the pressure pot (Level sensor sender unit) being blocked with sludge. You'll find this under the machine, either screwed to the RH side of the tub, near to the front of the machine secured by three Philips screws, or attached to the side of the big hose that goes from the tub to the pump,secured by a Jubilee clip, underneath the machine. disconnect the power and remove the pressure pot, in both cases it's a long rigid white plastic tube, from one end of which comes a narrow flexible plastic hose which goes up to the top of the cabinet and is attached to the pressure switch itself. This tube is likely to have a load of muck in it, as its bottom end. Clean this out, and if your element didn't burn out, then everything should now be fine.
1/9/2014 10:01:03 PM • Hotpoint WMA35... • Answered on Jan 09, 2014
Hi, I've just done a wash on my Hotpoint WMA35 but
Any flashing lights or extra solid lights on the control board? By "spin cycle", do you mean the final spin cycle and drainage of water through waste pipe (basically, I want to know if the washer spins then fails, or fails to begin any rotation of the drum whatsoever). I'm having problems with my WMA35 myself, so it'd be interesting to see if this a common fault.
9/6/2011 5:37:31 PM • Hotpoint WMA35... • Answered on Sep 06, 2011
My washing machine is very noisey.
Hi
Given below are the reasons of a noisy front load washer. Please check this link to get a detailed idea about your issue, it will help you troubleshoot your problem:-
http://www.doityourself.com/stry/front-load-washer-problems-loud-noises
Please get back to us if you have further query else please accept the suggestion. Thank you for contacting fixya.com
8/7/2011 3:27:50 PM • Hotpoint WMA35... • Answered on Aug 07, 2011
2answers
My Hotpoint WMA35 leaks water
The inlet water solenoid valve is faulty and must be replaced. usually it's right under the top cover where the inlet hose enters the machine. An easy DIY repair but remember to disconnect the electricity and water supply first.
3/9/2011 9:05:35 AM • Hotpoint WMA35... • Answered on Mar 09, 2011
Machine washes but won't spin
Hi
There are various reasons when washer won't spin.Please check the bellow link to troubleshoot your problem:-
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help#itdoesntspin
3/2/2011 5:18:30 PM • Hotpoint WMA35... • Answered on Mar 02, 2011
0answers
Mine says f-08
  • F08 - Heater relay cannot be activated
  • A thing to try is switching it off at plug and unplugging it for 5 mins to reset the machine then plug it back in and start a cycle and see if it comes back if it dose looks like you need to get the engineer out. hope this helps.
11/1/2010 7:09:15 PM • Hotpoint WMA35... • Answered on Nov 01, 2010
A manual
Go to:
WWW.HOTPOINTSERVICE.CO.UK
Follow the links in the menu on the left.
10/2/2010 7:13:27 PM • Hotpoint WMA35... • Answered on Oct 02, 2010
2answers
How do i change a door seal on a wma35 hotpoint
it can be changed through the porthole itself tho i find it easier myself to remove the front of machine as everything is easilly accesable that way ... once the bezzel has been removed the front is held by 4 self tappers remove these and lift front upwards to remove it from holding tags .. the seal itself is held by a large metal band you will see this quite clearly now ...
6/8/2010 6:42:47 AM • Hotpoint WMA35... • Answered on Jun 08, 2010
2answers
Wheres the filter on the wma35
The filter is located at the rear of the washer.
Remove lower rear cover, remove large black hose on bottom of drum.
Remove and clean plastic filter inside the hose.
Fit back and test.
4/3/2010 12:42:44 PM • Hotpoint WMA35... • Answered on Apr 03, 2010
How do i get to the filter on my aquarius wma30
You can try it by hand. Peep through the little pipe. You will find filter. You have to pull it out. put it back after cleaning. Do not forget to put rubber washer. After closing if you find water leak, run few length of teflon tape on the thread and tight.
4/2/2010 6:06:26 AM • Hotpoint WMA35... • Answered on Apr 02, 2010
The top off Hotpoint WMA35 washing machine?
Located at the front end of the top cover, are 2 plastic covers, prise them out with a small screw driver or something similar, and inside are 2 torx screws, get a torx screwdriver, and undo the 2 screws, if tyou don't have the correct screwdriver, you may be able to undo them with a small screwdriver.
Give the top a good hard push towards the rear, and it should come off..
Hope this helps.
12/28/2009 12:15:03 PM • Hotpoint WMA35... • Answered on Dec 28, 2009
Hotpoint WMA35 Front Load Washer Logo
56 questions posted
Top Hotpoint Washing Machines Experts
Paul Carew
Vernon Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Hotpoint Washing Machines
Most Popular Question
hotpoint aqualtis aqxx149pm get error
  • Washing Machines
