SOURCE: Epson R380 connected to PC can't use its driver on MAC OS X 10.5
Make sure that you have only loaded drivers for XP and that they are the latest ones instead of the MAC OS ones at http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=72086&prodoid=63059189&BV_UseBVCookie=yes&infoType=Downloads&platform=Windows&x=17&y=12
SOURCE: Printer EPSON Stylus Photo R380 quit accepting
Any solution yet??? I have the same exact problem.
SOURCE: Received
Well Rene its a sort of con trick by epson to make money from service. Get the ink tanks to pop out to the centre ( 0on startup of the run and take a torch and look back at the home base of the cassettes you should see a black square that is a sponge. carefully pick this up with tweezers or somthing that wont damage it.
Use blotting or kitchen paper and press the sponge in it to remove excess ink. wile the tray out and replace the sponge. Sometimes a small amount of like warm water and a few drops of bleach will dissolve the ink on the sponge.
Replace the sponge carefully ensuring it sits flat. repower the machine and it should now work OK You have just saved yourself $120 dollar service fee
please rate my help++++Thanks for using FIXYA
SOURCE: Replaced Ink carts on Epson
If you've replaced them in the past using the same ink there's a slight possibility that you have received bad cartridges. Have you tried or would you be able to swap the cartridges you have now with other cartridges just to make sure that it is not the problem.
Hope this helps!
