Measuring Tools & Sensors Logo
P
Patrick Chapman Posted on Jan 19, 2014
Do they sell pipe locators at home depot? - Measuring Tools & Sensors
Dan Lee
Level 1:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
Habit-Forming:
  • Contributor 15 Answers
  • Posted on Jan 19, 2014
Dan Lee
Contributor
Level 1:
Mentor:
Habit-Forming:
Answers
15
Questions
11
Helped
10815
Points
70
They don't have a huge selection at home depot but you are able to get one there.
1helpful
2answers
Am installing a Moen hand held shower ("Propel"). The instructions say I should install a backflow preventer. Where does that get installed? Inside the wall, or on the shower fixture itself?
Just buy a backflow preventer and install it in-between the pipe coming out of the wall and the shower head. Most (all?) shower heads have 1/2? standard pipe thread. Home Depot sells a backflow preventer with 1/2? standard pipe thread for $6.97.
Good luck and hope this helps.
Dec 27, 2017 • Moen Home
1helpful
Can I use self-fusible tape to fix leaking pipe?
Lowes and Home Depot now sell a water activated fiberglass tape that works for what you want to do. I tried in on a pressure pipe and it held pressure and didn't leak. Just read the instructions twice and install it according to instructions and you should be fine.
2answers
How do i fix a leaking copper pipe (it's not leaking from a connection of 2 pipes?) without having it cut and replaced?
You can now use click fix the permanent copper pipe repair clip from Burkert innovative solutions Ltd. Take a look www.burkertis.com
/uploads/images/fix-leaking-copper-pipe-s-not-leaking-34990601-5-1.jpg
Feb 22, 2014 • Plumbing
Dont know how to hook up the drain pipe
The drain pipe in what? If we are talking about a sink, they sell multi size kits at lowes, home depot and any other hardware store. You need to know the size of the outlet from the sink and the size of the drain pipe you are connecting to.
Broken blade andblade arm on ceiling fan
Go to your local Home depot or visit www.homedepot.com . I know they sell ceiling fan blades and arms at My local Home Depot in Ma, but depending on your location you may have to go to their website instead, I can only say...if they sell it in the store, more than likely they will have it on the website.
Good Luck with your repair.
--Eric
Oct 13, 2011 • Dryers
I have a badger 9 garbage disposal unit, and it leaks after installing from the discharge outlet at the top of the discharge tube under the side flange. I replaced a badger 1 and I used the old gasket as...
Location of leak is not known for sure.
Sounds like leak is where tubular drain pipe connects to side of disposal?
If leak is where disposal connects to sink, typically this connection is sealed using plumbers putty.
Open following link for disposal instructions:
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
1) If leak is at rubber gasket for tailpiece connection on side of disposal:
I don't know if your local home depot sells gaskets. Probably not sold separately.
2) Go to home depot and take rubber gasket out of a new garbage disposal box.
3) Or buy new disposal with a gasket, use the gasket and return disposal saying that part was missing..
4) To seal old gasket, use rectoseal white pipe joint compound.
Cover the gasket with rectoseal and then assemble parts.
Open following link above for photo of rectoseal.
I always use rectoseal on tubular drain connections for 100% seal first time every time.
5) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on plumbing or any do-it-yourself project.
Fixya is always less expensive than a service call.
Flapper closes way to quick. Have to hold handle down for complete flush. This is in an Amer. Stand. toilet. I have adjusted the chain and the flapper dail with no help. I work in the plumbing Dept. at...
Hi, American Standard uses a special large type of flapper that is designed for it. If I recall correctly,
It is black plastic with a device designed to delay the closing of the flap. It also has a special chain that is not like other flappers. Home Depot should stock these flappers. Fluidmaster makes a version of it that they sell.
Hope this helps,
Best Regards,
Mark
2answers
Cap to replace light kit
Hello. This is the home depot brand. remove all of the glass from the light kit and take it to home depot to be sure you get a cover that will fit properly.
Nov 11, 2009 • Dryers
HOME DEPOT GENERATOR HUSKY 5000 NEED PARTS LOCATED FOR GENERATO
bring the entire thing back... ask to speak with the manager and demand a brand new unit... (husky is exclusive to home depot..fyi)
if they give you push back ask for the district managers phone number (they have to provide or they can be fired) but they will replace it before he gets envolved..
if that fails try posting this in the correct category (this is motorcycles)
2helpful
2answers
I want to cut 2 7/8 inch pipe to make a 90 degree elbow, not a corner but a sweeping corner. I know how to cut 2 45's to make a corner but I want the corner rounded.
They make pipe benders for you application. They are quite inexpensive. If you want to do it your self you can. Remember the total number of degrees you want is 90. Each cut is half the angle. Example 45+45=90. 30+30+30=90. and so forth.
I don't know your application but they sell larger radias 90 degree rigid conduit elbows at Home Depot or Lowes.
Apr 24, 2009 • Plumbing
Top Measuring Tools & Sensors Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
