No filter. Thats with front loaders. Water left in the tub is two issues. #1 Kinked drain or clogged hose. If that is OK then your drain pump is bad and needs replacing.
The spin cycle is reliant on the drain pump removing water from the tub.
It is a common ocurrance of objects (ie hair pins, pegs, coins etc) to be mistakenly washed through the cycle. Washing machines will often flush these objects down through the drain pump, and get caught in the little propeller of the pump.
So, it is imperative that you inspect the drain pump first and remove any obstruction within the drain pump cavity.
Turn machine power OFF at the wall and remove the power plug.
i) place an empty bucket on the floor ii) lower the drain HOSE into the bucket - gravity will cause the water to drain into the bucket. Empty the bucket. Perform this procedure until all water has been emptied from the bowl. iii) move the washing machine out from the wall, to gain access to the drain pump (usually a large screwcap). Place a large towel on the floor, under the screwcap - this will catch any remaining water that escapes. iv) unscrew the drain pump cap and withdraw the cap. This cap may also contain a filter, so remove any lint/objects from this filter. v) with the pump cap/filter removed, look inside the pump cavity and remove any visible obstruction from the impellar (little propeller thing). Then, with your finger, turn the little impellar in both directions - if you feel a 'rubber band' like resistance, then the drain pump may be ok at this point. vi) remove all wet clothes from the machine bowl. vii) re-assemble the drain pump cap/filter and secure it in place. Install drain hose back into your laundry tub. Plug machine back into power. viii) fill the bucket with water and pour water back into your machine's bowl. Repeat with a 2nd bucket of water. ix) manually select and operate SPIN cycle on the machine. Observe if drain pump functions correctly and empties water from the bowl. If yes, then you have resolved the problem.
If your pump has been cleared of all obtstructions but your machine will still not empty water from the bowl, then a full diagnostic will need to be carried out by an authorised service agent to determine which component has failed.
This is
almost certainly a simple problem with your empty pump filter being clogged.
The empty cycle is timed and if it can't get all the water out in time because
the filter is blocked and slowing the empty down, then it will fail safe and
won't step on to the final spin cycle with excess water in the drum. While it's
trying to get the water evacuated, you will probably see the machine doing a
slow tumble for up to 8 minutes and you may also hear the empty pump running
too.
You need to
locate and clean the filter. Depending on the model (You haven
This is almost
certainly a simple problem with your empty pump filter being clogged. The empty
cycle is timed and if it can't get all the water out in time because the filter
is blocked and slowing the empty down, then it will fail safe and won't step on
to the final spin cycle with excess water in the drum. Locate and clean the filter. There is a round unscrewable filter cover on the front of the
machine at the bottom right, behind a small door. Many models of
this design also have a small hose to the right of the filter cap that you can
pull out, remove a plug from and drain off any water in the filter before you
remove the filter its self and get your floor wet, so take a look for this before you
remove the filter and get soaked.
If this IS the case, you need to call the repair guy out again and when he gets there, kick him all round the house until he gives you a refund foe his last 2 visits!
Your empty pump filter is blocked with debris. If it can't evacuate all the water then it wont allow the spin cycle to start. Locate the filter (probably behind a little door at the botton of the front of the machine). Remove, clean and remove the debris, re-fit and all will be well
If you are getting this code it is because your washing machine has tried for at least ten minutes to drain the water out of the machine. The most likely cause of this problem is that you have a plugged pump filter or you have something stuck in the pump filter.Make sure that you unplug your washing machine.To clean out the pump filter you must empty the washing machine water. The best way to do this is to manually drain the water into a low bucket or basin. Then lay a towel down to catch to remaining small amount of water. Remove the pump filter, clean out any debris, and wash out the filter. Then plug your washer back in and restart the washing machine.Check that your machine is properly leveled. A washer that is too far out of level may not drain properly. Make sure that you are level front to back as well as side to side.This solution will solve your problem Thank You !!
It's possible that the tub suspension system is out of position. Open the cabinet top (use a thin putty knife in each front corner to release a spring clip) and watch the mechanism while washing. Try shaking the assembly to see if you can spot something rubbing. Hope this helps!
Probably down to the water not emptying from the machine in the empty cycle and the machine won't spin because there's still water in the drum. If this is the case, the root of the problem is almost certainly a blocked filter, restricting the draining of the water and not allowing it all to pump out in time during the empty cycle. You probably need to find and clean your filter.
Hotpoint WF430 Front Load Washer
This video will show you how to find that leak on any front
loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
